Old 07-03-2007, 05:51 AM
xracerbob's Avatar
Cobra Make, Engine: ERA 758 KC Pond 482
Default Smiths gauges
Hi Bob-
I have a car on order and am deciding on the gauges. I was leaning toward the SW gauges since I have experienced less than stellar reliability from Smiths mechanical gauges in the past. Now I see that Smiths has a line of electronic gauges. Do you have any experience with them? Also wondering if the wiring harness would need to be different to accomodate them. I also like the idea of a volt meter instead of an ammeter.
http://www.nisonger.com/cobra-electronic-gauges.htm
Thanks,
Bob
Old 07-03-2007, 06:45 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Bob-
I used the autometer gauges and they are great.
http://www.jegs.com/webapp/wcs/store...63911_-1_10339
Replica is not a dirty word.
Old 07-03-2007, 08:08 AM
Cobra Make, Engine: SPF #298 427 FI
I dont see what the fascination with smith gauges is. I know they are the original type but they are unreliable and impossible to see at night. I have an autometer tack and the rest are smiths. I would go with autometer.
Old 07-03-2007, 08:26 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Interesting how things work . . . or doesn't work. I have Smiths gauges in my Cobra. No problems yet, but I did replace the plastic line running to the oil-pressure gauge with an AN hose as a safety precaution. However, I do have SW's in the GT40. Keep in mind that Murphy's Law always applies. The only problem I've had is a failed Stewart Warner water-temp gauge (mechanical) in the GT40. And what a bear it was to replace. This is because you can't just replace the gauge, but the entire capillary tube-and-gauge assembly. Being a mid-engine car, this required dissassembly of the interior of the car.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 07-03-2007, 10:04 AM
xracerbob's Avatar
I hadn't really looked at the Autometer's before. They look pretty nice. The SW's are made in Lancaster PA and I know a guy who works there. I think the Smiths do look the best, but I had 2 go bad on the FFR almost immediately. One was the oil pressure gauge and it filled up with oil and leaked all over.
Old 07-03-2007, 10:15 AM
Cobra Make, Engine: Superformance SP02228, ROUSH 402R w/custom DiVinci Performance Carb.
Default AutoMeter
I switched to Autometer... Now I can see them at night.
Old 07-03-2007, 05:05 PM
Cobra Make, Engine: ERA 289FIA, 289 stroked to 331, 392 HP
5 years and about 70,000 miles on the smith gauges in my MGB and I never had a problem with them.
Old 07-03-2007, 05:21 PM
1985 CCX's Avatar
22 years with Smiths and they are still running strong!
Old 07-03-2007, 06:56 PM
cobred's Avatar
Cobra Make, Engine: ERA #698 428 Toploader
I ordered my ERA with autometer gauges from ERA. Reverse speedo and a voltmeter, they look great and work perfect for 3 years so far.
