09-19-2007, 08:26 AM
ERA Quiz Question :)
I am off work this week, trying to finish as much of my rolling chassis as I can. Dropping the engine in tonight, hopefully. As I have inventoried the boxes from ERA, I have found this thing .. Whatizzit?
TIA,
Sam
09-19-2007, 08:47 AM
Cobra Make, Engine: ERA 739
I am thinking that is part of the hydralautic clutch linkage, but I am sure there are smarter folks out there than can answer the question.
TS
09-19-2007, 09:08 AM
Cobra Make, Engine: Building ERA #749 427 Cobra
Sam,
That is the alternator bracket setup. Most likely you will not be able to use the stock setup as it would put the alternator out to far and hit side of engine compartment. Also may depend on head configuration. By the way I took delivery of ERA#749 recently. Curious to know if you received all your parts.
09-19-2007, 10:05 AM
GA
That is correct - it is the alternator bracker assy. The thick piece bolts to the head.
09-19-2007, 12:04 PM
Wow! I never would've guessed alternator bracket. I bought the OEM Ford parts on EBay and didn't anticipate a problem. I'll let you guys know how it goes ...
Thanks!
Sam
09-19-2007, 05:13 PM
Thanks!
Sam
I used OEM Ford alt. brackets (see my gallery) and couldn't drop the engine in...the alternator interfered with the right coilover mount. Only then I found the kit bracket, and it works great.
09-19-2007, 06:22 PM
ERA also sells a nice upper bracket (the adjuster) that comes a silver color. Looks like ceramic. I think it was $35.
09-19-2007, 03:02 PM
tells you what I know  ....are you using a 427so?
09-20-2007, 07:37 AM
Cobra Make, Engine: Hurricane #1037, 351C, TKO 600
Nice Car
Sam,
It that Matt working the lift? If so you should have taken a different angle. Matts head is blinding me!!
Nice Ride, I hope you get done in time for Austin in MArch
Gregg H
Gregg H
Former TCC President
"Not the victory but the action. Not the goal but the game. In the deed the glory."
09-20-2007, 09:59 AM
Gregg! That's John Ross standing at the lift and me kneeling working the valve  Yes, I'll be in Austin in March, you can count on it. Hope to see YOU there, my friend!
Renew1, I failed to answer your question .. I received "most" of the parts. Only critical shortage were the driveshaft flange bolts which they are sending asap  Also, the MCO and ID plate come under separate cover according to Peter. I'm not too impressed with the 1/4-20 battery ground terminal in the trunk, but they don't give you enough cable to go down to the bumper bracket. So I'll have to drill and tap a hole, I guess, and rough up the powder coat. Or run a long cable down the side of the trunk floor - ugh! You know, for $500 for that rear mount battery .. well, I'm still delighted with the car.
Only other problem with ERA work was the front harness. the left parking light cable was wrapped about a foot too far down the main trunk. Had to tear off the tape and pull those wires back to get them to reach.
Pulling the dash now. I was sure delighted to see that all the harnesses are completely terminated and ready to plug and play - woo! Major time savings!
Sam
