Old 10-22-2007, 03:54 PM
Kramer's Avatar
Cobra Make, Engine: ERA 739
Default Fuel pump mounting
Does any ERA owners run a fuel pump...if so can you tell me where you placed the pump and how you ran you electrics....i.e. did you run it of the ignition switch as provided?
Also...if any ERA owners has a secondary (return fuel line) I will be very interested to understand the path you took iwth that line?
Kramer.
Old 10-23-2007, 09:35 AM
Loadco's Avatar
Cobra Make, Engine: ERA 427 SC
Here's where I mounted mine. Runs through ignition switch.
ERA #509
2003 Z06
Old 10-23-2007, 11:21 AM
Kramer's Avatar
Thanks Loadco....not a bad idea...since the folks at ERA had already preinstalled a lot of components (including the rear end and the fuel line) I was thinking it might be hard to get up there.....instead mine is mounted on the frame rail just forward of the driver side rear...it should work fine, but just wanted to check and see how others did it.
Old 11-01-2007, 06:52 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
My fuel pump in my FIA is installed in the space behind the driver's side rear wheel. A panel helps prevent rocks, etc. from hitting it.
Jim
PS: I'll try to take a picture of it tonight and post tomorrow.
Old 11-01-2007, 12:17 PM
Kramer's Avatar
Thanks Jim....I had help installing my engine and the fuel pump he mounted was on the frame just under the drives seat...should be ok, just wanted some additional thoughts/pics.
Old 11-01-2007, 10:38 PM
289FIA's Avatar
Proud Club Cobra Member
Cobra Make, Engine: ERA 2121
Kramer.
Anyone using a fuel tank mounted (inside) electric pump with or without the return line? Just curious...
289FIA
Display Modes
