Old 04-23-2008, 07:50 AM
mtr mtr is offline
Cobra Make, Engine: ERA 719, 302 5speed
Default Carpet on Tunnel
I'm having a little trouble getting the carpet to lay smooth on the tunnel, particularly on right side. I get a kink up near the front. Any tips?
Old 04-23-2008, 08:39 AM
When it comes to applying carpet, Jack has magic fingers. He can probably give you some hints over the phone. He's here early but also leaves at 3:30 pm Eastern time.
Old 04-23-2008, 08:45 AM
jams's Avatar
Cobra Make, Engine: B & B
I have heard of people using steam to soften and mold carpet to shape. I have never done it myself.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 04-25-2008, 03:42 AM
SLHetal's Avatar
The old Porsche 356s had wool square weave carpet that was hard to work with in areas similar to the cobra's tunnel cover. I always used a steamer when installing new carpet kits and it got rid of the wrinkles/kinks, etc. Just take your time and let the steam/heat do the work for you. I also used a small 3" wooden roller to assist me in pushing the hot carpet into tight spots, corners, and over humps. When the carpet cools it will tighten up, assume the shape of the area you are covering, and viola...no more problems.
Sam
Old 04-25-2008, 07:04 AM
mtr mtr is offline
I think I will give steam a try. I've left the carpet clamped over the tunnel all week and its somewhat assuming the shape now. I think the rest of the problem may be that the garage just isn't warm enough and its making the carpet stiff. All the bending over and working in tight areas is starting to make me a bit stiff!
Old 04-25-2008, 07:17 AM
ZOERA-SC7XX's Avatar
You might want to try a hair dryer set on max hot. It may give you just enough heat to 'pursuede' the carpet into position.
Old 04-25-2008, 02:25 PM
jdean's Avatar
There is a hot-rod, show car interior upholstery guy in our area that has done custom
carpet in several Cobras recently. He makes it look very tight and smooth in the corners and around all the humps etc. He says the only way to make it look right is to steam it to make to it stretch/form to the surface. After all there are very few square inches of flat surface in a Cobra cockpit.
6th generation Texan....
Old 04-25-2008, 05:31 PM
How do you apply the steam?
I hate when 'carpet tunnel syndrome' happens...
Old 04-25-2008, 06:32 PM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
I think that is "covered" under my medical insurance.
My wife has a upright clothes steamer that I used to steam my carpet.
Dave
55 mph is unsafe at any speed. Huh?
