| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
06-09-2008, 11:14 AM
ME
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Ray-
Call up Special Titles Division of DMV in Trenton, tell them you want to title a kit car and have them send you the "Reconstructed Vehicle" packet of information. It details all of the rules your car must comply with.
Replica is not a dirty word.
06-09-2008, 01:56 PM
NY
Cobra Make, Engine: ERA 758 KC Pond 482
Patrick-
You should be using the non lube type U-joints. They are much stronger and safer.
Lots of excellent info here:
http://www.dennysdriveshaft.com/html...eak%20u-joints
06-09-2008, 02:16 PM
Originally Posted by xracerbob
Patrick-
You should be using the non lube type U-joints. They are much stronger and safer. [/url]
You know I had that conversation with Bob P. about why ERA specs the Spicers with fittings as opposed to the Spicer "Life" U-joints. There's six of them on the car, too. I can't remember now what his reasoning was, but they continue to spec. the lubable U-joints over the non-lubable ones. Bob, any comment?
06-09-2008, 03:08 PM
ME
I only drive on the street so I went with the inboard brakes. If I were to build my car again, the only thing I would do differently is to go with the outboard brakes.
While it is true that you can remove the access panel to get at the inboard brakes, I find that removing the seats to get to the panel, and then reinstalling the seats when I'm done, takes longer than actually doing whatever type of servicing that I wanted to do to the brakes or rear in the first place. I know some people claim to be able to remove the access panel without removing the seats, but that hasn't worked for me- can't get my hands and a screwdriver back there with the seats in. It would be so much easier to just jack the car up, pop off a wheel and have full access to the brakes in 5 minutes.
The extra cost of the outboard brakes is not that much more than the std rear if you do it now, but if you want to retrofit it later on, it will cost you almost as much as it would have if you would have purchased the outboard brakes initially- I've asked about it.
So I would go with the outboard brakes now because you cannot easily (or inexpensively) upgrade that later on and forego some other options now which you can more easily upgrade letter on when the budget allows.
Plus, the outboard rear is so damn pretty to look at
06-09-2008, 05:00 PM
You live in a normal commom sense state
06-09-2008, 05:23 PM
Originally Posted by RICK LAKE
As far as the leg burn I thought you had this one figured out.  Buy a small welding blanket and cut it long enough to cover the sidepipe. Once out of the car, roll it back up next to the seat.
Yeah right, if I can't remember to step out over the pipes how am I going to remember to throw a cape down over the pipes? Who am I, Sir Walter Raleigh?  Oh yeah, are zerkless U-joints stronger than ones with fittings?
06-09-2008, 05:38 PM
CT
You might want to consider ordering all your options at the time they start building your car, as they are all installed at no extra cost. I made the mistake of buying my optional stuff after my car was complete, and thus I had to install everything. Also have Peter arrange your paint work, then you will not have to take the car apart for paint (another hard-learned lesson)...it will be done for you. My car has a 428 with a toploader...and is BLACK, with no stripes. It is just about done...only needs to work the bugs out and install the wipers and heat shields.
Good luck, you cannot go wrong with ERA.
06-10-2008, 04:05 AM
NC
Cobra Make, Engine: ERA #775
Your car sounds really nice... I really like the black, but my wife thinks I should consider a different color as my current car is black. (I hope I didn't go and ruin things, using the "w" word here. ) I wouldn't have swayed but really liked the color of the car in the pic earlier up in the thread.
(I did speak to the owner of that car for quite a time and he was so very helpful, but never did ask his name or the specifics on the colors. If anyone can help me with that, I'd appreciate it)
I share your thoughts about trying to get all the options I want at the start, and I guess that's what got me going with this thread; that and trying to gain knowledge from other people's experiences. I plan to keep this car a long time, so want to be sure it's about as right as can be.
Thanks for all the help.
Ray
| Thread Tools |
| Display Modes |
Hybrid Mode
