Old 12-01-2008, 06:48 PM
iwantacobra427's Avatar
Cobra Make, Engine: SOLD: ERA FIA #2114 with 331
Default Last issue before first drive...
Brake lights are not working. The relay works and I have power at the brake switch. When I powered the relay directly, the brake lights worked. I replaced the switch and still.. no brake lights. The only thing I can think of is that I'm not developing enough pressure at the switch to close the circuit. I spent a lot of time bleeding the brake lines. Any ideas?
Old 12-01-2008, 07:50 PM
cobred's Avatar
Cobra Make, Engine: ERA #698 428 Toploader
Jump the wires at the switch together to bypass the switch.
Old 12-01-2008, 08:47 PM
I did that too.. The brake lights work.
Old 12-02-2008, 03:30 AM
Check that the balance bar angle is adjusted properly. If the angle is set incorrectly, the pedal might feel firm but one side will not develop pressure.
Balance Bar Adjustment
