Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Everett-Morrison Motorcars -- Speak with Julie and Brett
December 2025
Old 10-15-2009, 12:52 PM
Cobra Make, Engine: Everett Morrison 347 stroker
Default New at this and need info
I have a EM that the title says is a 1994 year. Does this mean it was assembled in 1994? What gen EM is it? I also would like to get a copy of the assembly instructions. I need to raise the body front end about 1/2 inch to increase the fender clearance. Any suggestions other than tire size?
Old 10-15-2009, 03:22 PM
what size tires are you running? maybe you dont have to raise the body, just adjust the front suspension(coil overs).
Old 10-15-2009, 03:27 PM
Tommy's Avatar
Bob,
EMs came with several suspension options. Do you know which one you have? Can you provide photos?
Tommy
Previously owned EM Cobra
Old 10-15-2009, 06:58 PM
HYM810ANCE's Avatar
Cobra Make, Engine: Everett Morrison- 351C
My EM has the manufacture date code on the plate attached to the engine compartment and one on the frame also. Mine is a 1993. I will see if I can find my instructions for you, if I still have them I'll scan and send them to you. Bob is right, I think mine has Carrera Coil Overs and we adjusted them and I purchased different tires and wheels, rides great now.
I just looked through my files....no manual. But I did verify that the Carrera Coil Overs became stock in he early 90's, right about the time they offered the longer 93"-96" wheelbase cars.
"If it isn't gaudy...I don't want it." ~Ginger
Old 10-19-2009, 01:09 AM
The suspension is out of an 88 corvette. The pictures will be taken Wednesday. Running 16" wheels. I'm more interested in the posibility of raisinf the body 1/2" if feasable. What do you think folks?
Old 10-19-2009, 02:50 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
If you don't have coil overs, you'd be better off putting them on, then play with the suspension to get what you're looking for. You start tweaking the body in one place and you'll find trouble somewhere else. I dropped my floorpan 4" last winter and everything was fine for about a month. The all of a sudden the rear suspension was riding on the bump stops. I had to use the 4 link to adjust the ride height. Bring the trailing arms to a different angle.
Jack
XSSIVE .....
