Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Everett-Morrison Motorcars -- Speak with Julie and Brett
Old 11-10-2010, 09:10 AM
MOTORHEAD's Avatar
Default E.M. sn location, help!
Fellow E.M. owners:
Is your vin # on a data plate only, or is it stamped on the chassis also? If so, where is it located?
TIA,
Ted
"When Injustice becomes Law,
Old 11-10-2010, 09:34 AM
Hotfingrs's Avatar
I've got 2 data plates on mine, one under the dash and one under the hood.
Jack
XSSIVE .....
Old 11-10-2010, 09:54 AM
Z-linkCobra's Avatar
I have none on mine. I have been all over the body and frame and found nothing of a data plate or serial number.
I was once told that EM had frames and bodys made by an outside manufacturer that did not number them. They were to be numbered by EM at the time of completion...or something to that effect.
Old 11-10-2010, 10:50 AM
Hotfingrs's Avatar
Inside the body there is one on the left side, on the post under where the windshield mounts, and in the engine bay on the front cross brace.
Jack
XSSIVE .....
Old 11-10-2010, 12:37 PM
I know there is not one on the frame. I will check the body again tonight when I get home.
Thanks for the insight Jack
Gene
Old 11-10-2010, 12:46 PM
Hotfingrs's Avatar
Should be right beside your left left leg when your in the drivers seat.
Jack
XSSIVE .....
Old 11-10-2010, 01:36 PM
Ill check it out.
Thanks again
Gene
Old 11-10-2010, 03:56 PM
Tommy's Avatar
It may depend on who built it. The VIN plate on my car was riveted to the inner fender well, on the right I think.
Tommy
Previously owned EM Cobra
Old 11-10-2010, 06:12 PM
MOTORHEAD's Avatar
Thanks for the replies guys.
The problem is the dataplate vin, (stamped by ???) doesn't match the MSO vin, so I was hoping to find the vin stamped on the frame somewhere. It's fairly certain that the mso is correct (XX427SC) as opposed to the plate: (XX427SF) . We'll keep looking !
Old 11-10-2010, 06:44 PM
Hotfingrs's Avatar
Could be the plate is a mistake. My plate starts off EM427SCxxxxxxxxxxx Also what is on your title?
Jack
XSSIVE .....
