Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Everett-Morrison Motorcars -- Speak with Julie and Brett
Old 07-14-2014, 01:04 PM
Default Gen IV Alignment Specs
In answer to calls about the alignment specs for our GEN IV Cobra here they are:
Front Camber is 1/2 degree negative (-0.5)
Front Caster is 1/2 degree negative (-0.5)
Toe In is 1/8" inward
For the Rear 1/2 degree negative (-0.5)
Toe in - zero (0)
For earlier Gen III cars the Corvette front end was 4 to 6 degrees negative Caster and for the Mustang II front ends it was negative 2 degrees. The Camber and Toe In was the same as the newer car.
Your alignment shop can input these specs and set up your car without resorting to Corvette, Ford or other manufacturers data sheets.
Everett Morrison Motorcars
Display Modes
