Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Everett-Morrison Motorcars -- Speak with Julie and Brett
Old 11-16-2014, 07:49 PM
BADSN8K's Avatar
Cobra Make, Engine: BD 1445 Coyote TKO 600 3.91
Default relocating battery from trunk to engine area
is there a kit to relocate to front of car?
I have seen kits to relocate to back.
EM 90"
thanks
Old 11-17-2014, 04:44 AM
lnfletcher's Avatar
Why would you want to?
Old 11-17-2014, 11:16 AM
Arvin's Avatar
Cobra Make, Engine: Factory Five MK4
Breeze Automotive makes one for Factory Five Cars.
FFR MK4, 408 Stroker, TKO600, EFI, Guardsman Blue
Old 11-17-2014, 11:24 AM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
The E-M manual I received when I bought my car shows the forward location of the battery to be on top of the front crossmember using a GM battery tray and clip. Part numbers are: GM #006262122 (tray) and GM # 006270159 (clip).
Old 11-17-2014, 12:09 PM
Mike I's Avatar
Cobra Make, Engine: E-M Cobra - RCR GT40
EM 90"
thanks
COASTAL,
There's no kit that I know of to do this, but I wanted the battery mounted in the engine bay when I built my car, so I fabricated an aluminum bracket to support the battery in front of the engine and on top of the cross-member as Tom mentions. E-M offered four different chassis/suspension configurations, so that will ultimately determine how you should proceed. My chassis has the Corvette suspension option, which uses a C4 Corvette cross-member, so I can only offer detailed help if that's how your car is configured.
Btw, in answer to Larry's question "why would you want to?" First, I didn't want to compromise what little space was available in the trunk. I keep my folding top with me at all times, which would be impossible if the battery was mounted back there. Second, with a small block motor installed with significant setback, there's quite a bit of space between the water pump pulley and the radiator, so it looked like a good use of space. Also, being a lightweight motor, I figured it wouldn't offset the balance too much, and it hasn't. Third, the longer the cables, the greater the voltage drop. Lastly, keeping a battery in the enclosed trunk would require venting that's unnecessary in the open engine bay.
Mike...
