Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Everett-Morrison Motorcars -- Speak with Julie and Brett
Like Tree2Likes
  • 2 Post By airboat1
Old 09-09-2018, 09:46 AM
Cobra Make, Engine: Everett-Morrison - 351W
Default Side Pipe Flange Gasket
I have a 2004 Gen IV and I'm trying to replace the Side Pipe Gaskets these are shown on page 9 of the winter/spring 2004 catalog part number EG1.
Been trying to reach Tom or Julie, does anyone have a source? My header to side pipe flanges are flat that is not angled. The gasket has the 4 holes in the center and 8 bolt hole in the flange pattern as shown in the parts catalog.
I don't want to make them if anyone has a part number I'd appreciate the source where I can order them.
Steve
Richierich and TiernanEM like this.
Old 09-09-2018, 10:06 AM
Remflex exhaust gaskets (header - manifold - gasket) - OnLine Catalog
I used the PN 8032 on my BDR and they fit great.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 09-09-2018, 10:16 AM
FWB's Avatar
FWB FWB is offline
i used these on a kellison once
Cobra Valley's Cobra Header Collector Gaskets
Fred B
Old 09-10-2018, 04:27 PM
Default side pipe flange gaskets
Thanks guys this looks to be what I need, will place an order.
Steve
Old 08-03-2020, 08:36 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I bought my car back in 99,and one of the first things I had to do was have new headers made. I ended going back to EM when they were in Florida. i was told to box up my headers, collectors and mufflers and ship them to EM One piece for each side. EM welded the pipes then cut the header exit collectors to separate like the pipes they make. Turned out the engine was off set making 3/4" difference side to side. i ended up using some thick copper plate, hole sawed the holes and bolted together with the collector to filed to fit and match. I heated the mess to anneal and used all the bolts. I had both exhaust flange bolt patterns (Mustang-Fairlane and truck-full sized car. The header flanges did not have the outer most bolt holes so i was able to use 14 bolts per side Stage * the Chevy" 1" long 3/8 bolts and copper gaskets. No leaks since.
I used the SS V flanges and lengths of 3 1/2" exhaust pipe all TIGGED together Three sets of mufflers and Car Chemistry disk units in the collectors to extend collectors, mufflers all rear ward near the rear tires I then had everything ceramic coated inside and out.
Mike H
