Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Factory Five Racing
Old 09-16-2011, 04:40 AM
Cobra Make, Engine: Pilgrim, TVR 4.6 on carbs
Default Suggestions for transmission line up
All
I am a novice at this. I am about to order my FFR Mk4 complete kit, I have a 302 engine, approx 300HP, running IRS, standard wheels 15" and recomended tires as per FFR. Can you make some suggestions for me to simplify the next purchases. I need suggestions for flywheel, clutch, bellhousing, gearbox.
if you had part numbers or good description and where you bought it from this would be a great help. I am on a bit of a budget and want the car to be as reliable as possible.
Thanks for your help :-)
Rich
Old 09-16-2011, 05:18 AM
Rich, I can help you here. I offer complete drivetrain packages and with 300hp, I can put something together that won't break the bank. I would use a new Tremec T5 trans and bellhousing with a RAM clutch kit. If you don't care about overdrive ratios I can also supply a rebuilt toploader trans package.
Give me a call and we can discuss the options.
5027591431
Old 09-16-2011, 08:42 AM
bobcowan's Avatar
That's pretty darned good advice. 300hp in a 2200# car won't put much strain on the trans or clutch, even if you drive it kinda hard on the street. Stock T5, stock flywheel, stock BH, and a decent clutch will be light weight, relativly inexpensive, and last just about forever.
Personally, I would not use a toploader unless it was a 1/4 mile track only car. And even then, I would have to think about that pretty hard. I like an OD gear a lot.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 09-16-2011, 10:52 AM
Cobra Make, Engine: B&B 306/FORD
I have a b&b roadster 306 ford 350 h.p. Tko600 5sp. Ram clutch and ford bellousing. A ford 9'' with a3.73 gear. The trans has a .68 5th and at 75 mph the engine turns 2100 rpm. With alot of highway running this works well. One option is taller gear and .82 5th?
