Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Factory Five Racing
Old 05-30-2014, 04:11 PM
Default MKII shocks
Hi, gang...
Mine has original Pro Shocks, which clunk around and constantly need ride height adjustments to the coils because they don't have a lock nut. I know Koni is the new setup for FFRs, but what are maybe some options. Would the Koni's be a substantial improvement at $250 each? Thanks for your input. Kevin
Old 05-30-2014, 05:47 PM
LMH's Avatar
LMH LMH is offline
I have QA1's on my Hurricane. Good coil over shock but I don't know how they compare in price to Pro Shock.
Alba gu brąth
Old 05-31-2014, 07:35 AM
bobcowan's Avatar
The Koni's seem to work well. At the price, they're hard to beat, I think. And they are designed specifically for our cars.
Interestingly enough, you can improve the ride with the Koni's by replacing the springs with Eibach's.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 05-31-2014, 07:56 AM
Get a set of springs and adjustable koni shocks from Gordon levy. They make all the difference in the world on your FFR. They did for mine.
Jim
Old 06-06-2014, 06:26 AM
Thanks guys!
Old 06-06-2014, 06:46 AM
super's Avatar
Cobra Make, Engine: Superformance, #011
I have just replaced my old coilovers.
The new ones are Öhlins - really fine stuff - they work pretty good.
(look there: Club Cobra - super's Album: SPF #011 - Picture )
But I am not sure if get those parts in the USA.
Werner
Old 06-06-2014, 07:41 AM
Frank Messina's Avatar
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
Not sure what you mean by "they don't have a lock nut". Are you talking about the nut on the end of the threaded shaft on the shock? That has nothing to do with ride height. You should put a hose clamp around the body behind the adjusting collar to hold your height setting. If the shocks are worn you can send them to Naake Suspension in Roseville, CA for a rebuild. Their work is excellent and an inexpensive alternative to buying new coilovers. I recently had mine done there and bought stiffer springs as well. Great service and excellent prices.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
