Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Factory Five Racing
Old 05-04-2003, 08:23 PM
Default FFR Rear Coliovers
I've just spent a couple of hours today trying to adjust the rear ride height with the cut down mustang 5.0 coil springs -- not a fun or easy thing, at least for me. So, is there an option to remove the 5.0 spring and shock and replace it with a coilover other than using the $600 option from FFR?
Old 05-04-2003, 08:41 PM
mikiec's Avatar
There was a group purchase over at ffcobra.com very recently on some Pro-Shocks setup for the FFR. The price was much less than the shocks from FFR. I suggest you go there and do a search. There were also, par tnumbers listed with the correct valving.
Old 07-16-2003, 05:54 PM
I may be wrong but here's an idea...I would think since the majority of the stuff on the FFR cars is designed around the fox mustang, just about any suspension component/manufacturer of parts for a fox should work on the car. For example, a Maximum Motorsports rear coil over conversion, etc...
My SCrew'd Garage
Old 07-16-2003, 06:14 PM
DavidWard's Avatar
Cobra Make, Engine: FFR 1204 With Stack Injection
Send a message via ICQ to DavidWard
Here's my set-up, about $300 from Speedwaymotors. I fabricated my own mounts.
http://members3.clubphoto.com/david251117/guest-1.phtml
Old 07-16-2003, 06:21 PM
Both I with my B&B and Phil Manro with his ffr went with a setup from VPM http://www.vintageperformancemotorcars.com/
I can honestly it was the one mod that made the most differance it the cars overall performance It even took away the wheel hop problem I had
The best $ I spent so far. Plus Craigs a great guy to work with.
Greg
www.upstatecobras.com
founding member
