03-03-2004, 05:08 AM
SC
Since your going carb'd(they supply you with a wiring harness), and the non donor route, your going to need to purchase the following parts:
CLUTCH CABLE
ACCELERATOR CABLE
TRANSMISSION MOUNT W/BOLTS
DRIVESHAFT AND 4 ORIGINAL BOLTS
SPEEDOMETER CABLE
CIRCLIP, CLUTCH CABLE RETAINER
MOTOR MOUNTS, RUBBER BUSHING, REAR EXHAUST HANGER
UPPER RADIATOR HOSE, RADIATOR W/CAP
LOWER RADIATOR HOSE
FAN SHROUD W/OVERFLOW TANK MOUNTED
FUEL TANK W/CAP AND MOUNT STRAPS, EMERGENCY BRAKE HANDLE, CABLES, W/HARDWARE
BRAKE ASSEMBLY, SPINDLES, FRONT
CONTROL ARMS, REAR UPPER W/BOLTS/NUTS
CONTROL ARMS, REAR LOWER W/BOLTS/NUTS
REAR AXLE ASSEMBLY, COMPLETE, A-ARMS, FRONT LOWER, UPPER STEERING COLUMN, W/IGNITION, TURN SIGNAL STALK, NON-TILT ONLY
STEERING RACK W/TIE RODS, ENDS, BOOTS, NUTS, MOUNT BUSHINGS
STEERING SHAFT ASSEMBLY, W/LOWER U JOINT, OEM NUTS/BOLTS, HORNS
IGNITION CYLINDER WITH KEY
VACUUM RESERVOIR, CYLINDER SHAPED, BLACK PLASTIC
GROUND STRAP, BATTERY CABLE WITH TERMINAL, PEDAL BOX, BRAKE CLIP AND (2) PLASTIC WASHERS, ACCELERATOR PEDAL
Bill S.
