Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Factory Five Racing
Old 06-11-2007, 01:17 PM
Ron61's Avatar
Question Need Information
I need to know how to get to the driving lights to tighten them on my Coupe. The Left one is loose and I can find no way to get in there to tighten the swivel it seems to be mounted on that lets it be adjusted up or down. I am talking about the two small lights on the picture below. Thanks for any help or information anyone can give me.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 06-11-2007, 02:43 PM
xlr8or's Avatar
If all else fails cut in from the back side???
Isn't the cavity where those mount the same place the front end pivot mounts are attached?? If it is you may have to remove the nose from the car.
Old 06-11-2007, 03:37 PM
Ron61's Avatar
The whole front end is one piece and removing the nose alone can't be done. When you remove the front end, the lights and everything come with it as all you do is disconnect the leads. I don't know how they put those darn things in as I can see the whole mounting cavity from inside the air intake and there are no bolts or screws that goes to the little bracket on the bottom of the lights. The only thing going into the cavity besides 4 bolts that help strengthen the front end by bolting to the frame are the lights leads. But they had to get them in there some way and by them being on a swivel to tilt them up or down I would guess there is supposed to be a way to adjust them.
Ron 61
Ronnie Widener
Old 06-11-2007, 11:13 PM
wtm442's Avatar
Beam Me Up Scottie
Do not drive at night!
Warren
Old 06-11-2007, 11:17 PM
mikiec's Avatar
Ask question here: http://www.ffcobra.com/ubb/ultimateb...forum/f/5.html
Old 06-12-2007, 06:11 AM
Ron61's Avatar
Thanks Mike. You too Warren.
Ron 61
Ronnie Widener
