Old 12-11-2009, 07:58 PM
*13*'s Avatar
Slightly Off Subject but... What does a sleeve job Cost?
ERA FIA 2088
Old 12-11-2009, 08:22 PM
Probably depends on your area but around here it is about $100-125/hole plus the sleeves.
And as others have mentioned done correctly sleeves are normally just fine. You can absolutely remove the old sleeves, there is more than one way to do it but cutting them out works very well.
I used to be an engine builder for 15+ years and we sleeved blocks all the time. Most of the time it was not all 8 as the cost was normally out of sight but if the block was rare enough we did it.
Hope this helps.
Chris
Old 12-11-2009, 08:35 PM
Gunner's Avatar
Cobra Make, Engine: ERA 707, 446ci FE
Mmph. Snork. <runs away giggling into his own sleeve>
<hollers back> "Twenty bucks, same as in town!"
= Si Opus Quadratum vis, angulos praecidere noli. =
Old 12-12-2009, 07:03 AM
I guess I should have said per cylinder.....
Old 12-12-2009, 03:25 AM
undy's Avatar
Sorry... can't help myself. You'll have to ask Tiger
Too many toys?? never!
Old 12-12-2009, 08:07 AM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
It cost me $80 per cylinder as the builder who did the work was on the "payroll" for all machine work on this specific build, plus he's a friend.
I was lucky enough to find an original 427 SO block for $1500. The cost of the block was "low" because it was .060 over on all cylinders.
So, I ended up with an original, seasoned and updated SO block for just under $2200.
Old 12-12-2009, 10:15 AM
dlampe's Avatar
Can you see any trouble with 8 sleeves in a block the is .080 over already with 2 bad cylinders that have already been sleeved? As I said, the sleeved cylinders were bored to 4.335 to accommodate the sleeves.
High Maintenance Racing Team
Run & Gun 2003 - 2013
