January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 12-12-2009, 05:04 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default fe oil filter housings
who sells the oil filter housing,bracket,engine mount for the fe's?, i have seen pictures of the oil filter mounted off the waterpump,just curious how much the set up costs. i have the canton oil filter housing that mounts to the block but in a ffr you are limited to the short filter.
Old 12-12-2009, 05:38 PM
Gunner's Avatar
Cobra Make, Engine: ERA 707, 446ci FE
ERA sells one setup. It's very nicely done with all premade hoses and the mounting bracket. I'm about to modify my setup to include an oil thermostat.
= Si Opus Quadratum vis, angulos praecidere noli. =
Old 12-12-2009, 09:45 PM
mickmate's Avatar
I have the brackets, I get the filter housings from Finishline.
mickmate
http://www.actoncustom.com/
Old 12-12-2009, 10:24 PM
Cobra Make, Engine: CSX4000, 427
I think Dave Dralle makes them. I bought one of of him. Quality piece.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 12-13-2009, 09:06 AM
i saw a picture on one of the shelby sites that included all 3 pieces, but there was no price?.
Old 12-13-2009, 12:38 PM
Gunner's Avatar
Finish Line gets $95 for the remote mount and $65 for the screw-on adapter. The mounting bracket is just a flat plate, shaped and drilled. You might consider fabricating it yourself. That, or ask ERA or mickmate for a price on the piece.
Does anyone know what the remote mount's native four holes were supposed to bolt to? Is it just meant to be a generic mount, or did it fit something specific once upon a time?
Old 12-14-2009, 11:41 PM
Ralphy's Avatar
Here is a double mount and single. I'm pretty sure this fits (3/4") the ford filter.
http://www.summitracing.com/parts/TRD-1030/
http://www.summitracing.com/parts/PRM-1211/
They have others.
Old 12-15-2009, 06:17 AM
mickmate's Avatar
Hey wrench I see you have a small block. If you want the period correct look then the Finishline part will do it (with my bracket of course) or if you just want the remote filter then your local auto parts or the Summit route is the way to go. If you want help with either to fit a SB water pump bolts let me know.
mickmate
Old 12-15-2009, 09:07 AM
i have a 445 fe to replace my small block, i like the look of the shelby bracket it is a cast piece,with built in spacers. i can easily make the steel one like era shows.
Old 12-20-2009, 11:19 AM
Cobra Make, Engine: Kirkham #570 w Shelby FE
If your not worried about originality, another option is the Kirkham mount.
I'm not sure what the price is, but it seems like it was about the same as the finishline setup. The Kirkham has one advantage in that it accepts the ORB fittings which eliminates the AN to pipe adapters. (one less joint)
Old 12-20-2009, 11:31 AM
Gunner's Avatar
Originally Posted by Ronbo View Post
IThe Kirkham has one advantage in that it accepts the ORB fittings which eliminates the AN to pipe adapters. (one less joint)
My OEM-style system has 1/2 NPT ports, for which you can get swivel hose ends (AN-10 to 1/2 NPT). No adapter nipples needed.
