November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-31-2010, 07:37 AM
Just replaced the CVR starter on my ERA / Ponds 482 about three weeks ago . The problem with the CVR is that it doesn`t have a pinion support . Any side load ( which you will have ) causes the starter gear to try to climb out of the ring gear , which introduces a severe load on the starter shaft , bearings etc ... it broke my starter shaft .
Went with the RobbMc unit with the optional support .... expensive , but what does a new flywheel cost ? Also , Made in America . The unit is actually smaller in diameter then the CVR and easier to install .
My first starter was a Powermaster and that was removed and sent back for warranty as it wouldn`t bolt up correctly ... the bolt holes were off .
I agree with the other guys here ... but remember that you are putting loads on the starter that were never thought of by the designers .
Rate This Thread:
