Old 05-31-2010, 06:15 AM
FUNFER2's Avatar
Default Billet Specialties Swivel Neck Thermostat Housing ?
Fas anyone used the Billet Specialties Swivel Neck Thermostat Housing, that has the O-ring ?
How well does is seal ?
Do you get a new o ring every time you remove the housing ?
I assume you don't used a gasket or silicone because of the O ring ?
It would be nice to point it in any direction you need.
Looks great too.
Regards,
Kevin
Old 05-31-2010, 07:21 AM
undy's Avatar
Toss the notion of the thermostat housing and go with an OEM looking expansion tank. It will look a WHOLE LOT better.
Too many toys?? never!
Old 05-31-2010, 07:40 AM
Roush #1's Avatar
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
Kevin,
Yes, I use that thermostat housing.
It took about 2 hours in all to stop the leaks.
My housing leaked until I machined enough of the housing away to get at least thirty thousandths of an inch of compression on the O rings.
If you go ahead and machine the housing before you start you wil save a lot of time.
I installed, removed and modified the housing 3 times before I stopped the leaks.
I think you would be wise to replace the O ring if you remove the housing.
They are cheap and readily available.
Hope this helps.
Good lluck!
J
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
Old 05-31-2010, 07:48 AM
I replaced the o-ring with a regular thermostat gasket with RTV on both sides.
No leaks, yet!
Jim
Old 05-31-2010, 08:33 AM
FUNFER2's Avatar
hehe, ya assumed that it would not seal with the o ring but, if you use just sealant, it would be like any other standard housing, jhv48 did. I sand casted then polished my housing and kept it before I sold the motor and very happy with it. I have a photo somewhere.
Just was curious about the Swivel Neck.
Regards,
Kevin
Old 05-31-2010, 10:46 AM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
I used their version for a windsor, which has an even more suspect O-ring set up (kind of a pear shape to accomodate the water outlet)
Surprisingly, it hasn't leaked at all since install about 2 years ago. Even had it off and reinstalled it at least once. I used the the clear silicone (non-adhesive) goo that I use on my pool filter gasket. No other gasket or sealer. No problems so far.
Matt
Hurricane Motorsports #1053; 427w
