Old 06-23-2010, 06:49 PM
Default 428fe head gasket recommendations
What head gaskets are people having the best luck with?
I am using mr gasket ultra seal 5790g (dry) and they are leaking oil.
Edelbrock 7337?
Fel pro z1020?
Sealer or no sealer?
Thanks for your help!
Old 06-23-2010, 06:51 PM
Forgot to add:
iron block and edelbrock heads.
10 to 1 comp
450hp
Old 06-23-2010, 06:59 PM
Fordzilla's Avatar
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Use Cometic. We use them exclusively.
http://www.cometic.com/
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
Old 06-23-2010, 07:21 PM
The 1020 Felpros work just fine.
Old 06-24-2010, 07:41 AM
Cobra Make, Engine: ERA #696, Ford 427/482 CO
At SUMMIT:
Fel-Pro 1020 costs $36.95 each
Ford Racing M-6051-A427 costs $37.88 for a pair.
It is the same gasket.
HOB
Old 06-24-2010, 08:26 AM
dcdoug's Avatar
How good are their FE valve cover gaskets? What material?
www.partskeeper.com
Old 06-24-2010, 10:40 AM
FWB's Avatar
FWB FWB is offline
gary, if you have iron heads and an iron block the absolute best gasket is the ford steel shim, and engine enamel as a sealer. it'll take over 12:1 compression. hard to find but they are out there. for street the felpro works fine too, no sealer
cometic....101.00 is too salty for me and it looks like its only avail in .030 overbore for the 428
Old 06-24-2010, 11:50 AM
Default fe valve cover gaskets
Here is the ones I use.
All rubber
http://www.summitracing.com/parts/FEL-VS-13049-R/
No leaks.
My old cork and rubber ones leaked.
Old 06-24-2010, 12:09 PM
You asked for help about 'head gaskets' but you're talking VALVE COVER gaskets.
Back to the classroom.
Chas.
Old 06-24-2010, 12:12 PM
Fordzilla's Avatar
Doug, The Cometic Valve Cover gaskets are advertised as aramid fiber. Not sure if they are available for the Ford FE or not. I can find out more about the Valve Cover gaskets if you want.
The Cometic MLS Head Gaskets are:
"MLS (Multi Layer Steel) The Cometic MLS gasket is comprised of three layers of Stainless Steel. Cometic uses Stainless Steel for increased strength, its ability to rebound, and corrossion resistance. The outer layers of the gasket are embossed and coated on both sides with a flouroelastomer rubber based material (Viton) designed to meet the demands of a variety of harsh sealing environments load conditions and surface finishes.
The Viton coating is resistant to 250 degC or 482 degF. The center or shim layer of the gasket is comprised of an uncoated Stainless Steel layer which can be varied to accomodate multiple thisckness requirements. The MLS gasket is ideal for both aluminum heads to cast iron blocks and aluminum heads to aluminum blocks."
FOR THE FORD FE:
A variety of thicknesses are available, and here are some part numbers for different size bores:
"part #C5833-040 for 4.080 bore, part #C5834-040 for 4.165 bore, part #C5835-040 for 4.250 bore, part #C5840-040 for 4.400 bore"
Mick
Old 06-24-2010, 12:32 PM
dcdoug's Avatar
All rubber
No leaks.
I have these right now and I think they are leaking. Since I just put them on a few months ago, it pisses me off. I will check valve cover bolts, etc, to be sure before going through the PITA of scrapping all that Right Stuff off the covers and re-doing.
http://www.summitracing.com/parts/FPP-1632/
www.partskeeper.com
Old 06-24-2010, 12:34 PM
dcdoug's Avatar
Sorry for the short hi-jack. Seemed related?
www.partskeeper.com
Old 06-24-2010, 12:58 PM
Hey, a leak is a leak is a leak. Right Chas?
Old 06-24-2010, 01:17 PM
Don't dimiss "misting" for the source of your leaks. Look around your pcv lines for a brownish stains where it's misting out, use a white paper towel to wipe around the backs of the heads, etc. before you call it the valve cover gaskets for sure. And if it's just a couple to three drops after a hard run, ignore it.
Old 06-24-2010, 01:24 PM
dcdoug's Avatar
Yeah, I need to spend more time on it. It is mostly after a hard run, but is more than 3 drops, but not much more. Since I am going to change out the pan in the next few weeks, which isn't leaking, but is only a street/strip pan, I figured I'd wait to chase leaks until after that. It's not bad right now and I could probably live with it, but I want zero leaks and naively believe that is possible. The oil adaptor block could also be suspect, but I don't think that's it anymore.
There you go Chas, how was that for a re-jack?
www.partskeeper.com
Old 06-24-2010, 01:34 PM
DOUG!
A. I am NOT the the hi-jack police.
B. GARRY-the OP made the faux pas-NOT YOU!
Chas.
Old 06-24-2010, 01:44 PM
Certainly. I'm starting to leak rather badly myself...
Chas.
Old 06-24-2010, 04:40 PM
I use a Fel-Pro race cork gasket. I find that the corks will weep a bit, but still seal an FE better than the rubber ones - which do not work well at the intake to head interface. A dab of silicone at that joint does the trick.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 07-04-2010, 11:13 AM
PANAVIA's Avatar
The felpros seem to work well as head gaskets in this situation , but the edelbrocks should work even better
Steve
