Old 07-16-2010, 11:10 AM
dcdoug's Avatar
Default Blue Thunder 427 MR vacuum port?
My "new" Holley 3255-1 does not have any vacuum ports on it. I am going to need a vacuum port to get the idle mixture set properly and I believe the picture below shows a port on my Blue Thunder 427 MR intake that I can use. (The one with the plug to the right of the carb return spring bracket mounting point) Is that right?
If so, what fitting do I need and should I leave the fitting in and cap it or put the plug back in when I am done?
www.partskeeper.com
Old 07-16-2010, 04:35 PM
FWB's Avatar
FWB FWB is offline
doug, get a fitting 3/8-18 npt male to fit the manifold, with a 1/4 or 5\16 hose nipple on it, napa has them in brass, simply put a rubber vacuum line cap on it after setting up the carb. and it will then be easily used again if needed
fred
Old 07-16-2010, 04:53 PM
dcdoug's Avatar
Perfect. Thanks.
www.partskeeper.com
