Old 08-18-2010, 02:41 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default erson rocker question
i am using edelbrock heads and erson rockers on my 445 fe build, i have the arp studs to hold down the ersons does any one know what the tourque spec should be ? i have them at 25 ft pounds now. there was no value on the erson instruction sheet?.
Old 08-18-2010, 03:39 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Check here: http://www.edelbrock.com/automotive_.../6000/6005.pdf The torque is different depending on whether you're using assembly lubricant or engine oil on the threads.
Chris
Old 08-18-2010, 03:53 PM
undy's Avatar
Same setup as yours, 40 ftlbs.
Too many toys?? never!
Old 08-18-2010, 03:54 PM
Cobra Make, Engine: Superformance aluminum427
Default Torque
I have the same setup too, I used ARP lubricant an torqued mine to 35 pounds, just make sure you don't bottom out the stud before you torque the nut, because it will eventually jack the helicoil out, I found out the hard way. Just screw the stud in all the way an then back it out 2 or 3 turns then torque. Thats the way I do it Good luck
Old 08-18-2010, 03:56 PM
i looked that up it is 35 to 45 depending on the lube you use. thanks for the info.
Old 08-18-2010, 08:59 PM
Remember to use the AN washers that come ith the Ersons and not the fat washers that come with the stud kit. The fat washers will sometimes hit the rockers. Also be wary if you're using head studs - the top of the stud will hit the bottom of the Erson mounting stands - clearance required...
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 08-19-2010, 05:12 AM
Clois Harlan's Avatar
Same set up for 8 years now and no issues ....40# torque done in a pattern (left center-right end-right center-left end) take it to 25# torqure first then take it to the 40# and after you run your engine in a bit go back and check all your head torques.
Clois
"Let's roll"
"Be part of Something Good
Old 08-19-2010, 05:20 AM
when i installed the studs i did tighten them with a small allen wrench, should i back them off 2-3 turns?
Old 08-19-2010, 06:49 AM
I don't think so! Maybe Brent Lykins, Jerry Clayton, or Keith Craft can help you out on this topic. Once I put my studs in I haven't touched them.
Clois
"Let's roll"
Old 08-19-2010, 06:52 AM
wrench87
I have the same set-up as you. Mine were torqued to 45 pounds by my engine builder. If I recall correctly, Keith Craft, whom I purchased the heads and rocker assembly from, uses the same value.
Old 08-19-2010, 08:23 AM
For a 3/8" coarse thread into the head and fine thread on top it is 40ft-lbs using ARP Lubrication.
Old 08-19-2010, 07:13 PM
ARP like to see studs very lightly tightened. Many aircraft trained mechanics prefer to see them loose - unbottomed. I know of at least a couple high end builders that like to use a ball bearing in the bottom of a threaded stud hole so that the stud is not forced sideways by the threads as it it tightened.
