Old 10-07-2010, 01:40 PM
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
Default Catch Can Setup
Hello all,
I'm looking to install a radiator overflow catch can and am looking for some ideas.
Anybody out there have pictures of their setup?
What setup / parts have you had the best luck with?
There are a ton of options out there and am just looking to circumvent the search process a bit.
Old 10-09-2010, 08:52 PM
Originally Posted by BDR879 View Post
Hello all,
63 reads and no responses?
C'mon guys, what are you using. I'm looking for a recirulating system and am currently looking at the following:
http://www.summitracing.com/parts/CSI-931B/
What's everybody else using??
Old 10-09-2010, 09:24 PM
Barnsnake's Avatar
The item you linked to is just a catch can. You could use it as a recovery tank by mounting it upside down, plumbing the radiator overflow to the bottom, and leaving the petcock open as a vent. The downside is that you can't see the level and you can't easily add coolant to the recovery tank.
Use of a recovery tank is handy in a cobra to help keep the air out of the system. Since the top of the radiator is lower than some parts of the engine cooling system, if you are overflowing at the radiator cap it will systematically pump coolant out until there is air everywhere above the radiator cap. Use of a high mounted "surge tank" is one way to address the problem, but a recovery tank is the most effective at keeping air out of the system.
Old 10-10-2010, 01:00 AM
Default overflow tank
i put one from summit, a nice looking polished aluminum unit. #SUM-300101-W,$60. i was always adding coolant. i put it inside the fender with the included brackts,took the overflow hose from the expansion tank put it on the bottom hose fitting, added a hose from the top one (leave this one open) down. there is not any on the ground anymore and i havn't added any coolant since. engine warms up the coolant flows from the expansion tank to the recovery tank, as engine cools the coolant is sucked back to the expansion tank. works great and looks good.
Old 10-10-2010, 11:05 AM
Ray,
Can you post a pic?
Old 10-10-2010, 01:39 PM
I went down to the local parts house and bought a plastic overflow tank off the shelf. Bolted it to inside fender area. I think it was less than $10. Anyway, it looks a lot better than the Gatorade bottle I was using before...
Old 10-10-2010, 04:25 PM
I was considering using an empty bottle of margarita mix. Same color as the coolant
Or maybe I should use margarita mix as the coolant....hmmm, I may be on to something here
Old 10-10-2010, 04:40 PM
This was just talked about 1 month ago. I guess you weren't paying attention.
http://clubcobra.com/forums/showthread.php?t=106611
Here's the one I used. http://www.summitracing.com/parts/SUM-G1474/
