LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-18-2010, 10:42 AM
philminotti's Avatar
Default Carburetor recommendation
Well I've pretty much had it with my fuel injection system. The Mass-Flo system is coming off. As for why, basically, I just can't get the thing to work properly.
So, for a 482 to be mostly street driven, what do you guys recommend? Hydro roller cam .633 248/252.
Thanks.
phil
Old 10-18-2010, 10:52 AM
RodKnock's Avatar
I have a Holley 850 on my 482 with similar cam specs, but I want this one.
http://www.holley.com/0-80676.asp
Old 10-18-2010, 11:06 AM
undy's Avatar
Go with the 1000 ultra HP. Ive been told by several people in the know that the 950 is just a massaged 750 baseplate (smaller butterflies).
Too many toys?? never!
Old 10-18-2010, 11:17 AM
"allow for Infinite Tuning and Tayloring..."
Tayloring?!? Let's hope they build them better than they write.
Old 10-18-2010, 11:18 AM
RodKnock's Avatar
I've heard that too, but the Ultra HP 950 was awesome on my old Corvette's 540ci engine. The Holley 1000 is an HP, but not an Ultra HP, if that makes a difference to anyone.
Here's a Holley sizing chart:
http://www.holley.com/data/types/pic...P_IntoZOOM.jpg
Old 10-18-2010, 11:21 AM
RodKnock's Avatar
I should add that up to 500ci and 6,500 RPM, the various Holley 950's are recommended, per the sizing chart.
Old 10-18-2010, 11:59 AM
dcdoug's Avatar
It's going to look waaay faster sitting in the garage with that carb on it.
www.partskeeper.com
Old 10-18-2010, 12:00 PM
Custom built Quick Fuel, made specifically for your engine/car.
Yep, I sell 'em.
Old 10-18-2010, 12:05 PM
RodKnock's Avatar
It will and you "know" me all too well.
It's also cheaper than a SOHC engine. I have to figure the "What's next?" angle for my car, otherwise I'll get bored. I have to look forward to changing something on the car.
Old 10-18-2010, 12:08 PM
The more you drive it, the more it will break down giving you stuff to fix.
Old 10-18-2010, 12:16 PM
RodKnock's Avatar
No, you don't understand me. I like to fix things that aren't breaking or broke.
Old 10-18-2010, 12:26 PM
dcdoug's Avatar
I'm sort of the opposite. I like to replace new, modern stuff, with really old stuff, making it much more likely to actually break, requiring me to ask a bunch of inane questions about easy stuff and accomplish the following:
1) Patrickt gets to work on his post count
2) ERAChas gets to berate me for over-thinking stuff AND comment on Patrickt's increasing post count
www.partskeeper.com
Old 10-18-2010, 12:28 PM
Dysfunctional, but accurate nonetheless.
Old 10-18-2010, 12:53 PM
Chaplin's Avatar
Phil-
Call Biggs, give them them all of the relevants details on your engine and they will build to suit. I have one of their carbs on my car now and I know someone else who does as well, and both mine and theirs were almost spot on out of the box and have been absolutely trouble free. Good support and prices are very reasonable as well. I hope this helps with de-modernizing your build.
http://bigsperformance.com/
Replica is not a dirty word.
Old 10-18-2010, 01:13 PM
Thanks for all the replies, guys.
phil
Old 10-18-2010, 03:10 PM
Gaz64's Avatar
Yep, I sell 'em.
Yes, QFT gets my vote for four barrel carbs, NO.1 choice.
Old 10-18-2010, 04:12 PM
I have some pretty good contacts at Quick Fuel. They have a carb that is referenced as an "850" that is notably better than the old Holley 850 DP, which is something of a turd. The Holley has a virtually straight venturi section, while the QFT has a better waist shape for improved signal. Obviously, a smaller waist should have an impact on flow numbers - but none of them flow what is claimed anymore. That ship sailed ten years ago....
The Holley 900HP is essentially a 750 with an 850 baseplate and an improved center section - what was once a very popular modification and is a very nice running carburetor for street and track use on moderate sized engines. The 1000HP is 850 based, and the HP center section is better than the old DP, but not as good as the QFT.
Of course I prefer Dominators on my bigger engines - but you rarely seem to find those on Cobra or road race style applications.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 10-18-2010, 04:57 PM
www.performancecarburetors.com
They will do a very nice custom carb for you at a very good price. They are holly based. Pro Systems are good to but expensive
Old 10-18-2010, 06:26 PM
greg schroeder's Avatar
The best carb I had on my Roush 427R single plane intake was a Pro Systems 1060 cfm mechanical secondary. Awesome for street, linear any throtle position, light switch performance, cruises at 1800 RPM in 5th(.64) 3.73 rear gear 28 inch tall tire, increased the HP by about 30 at the tires.
off idle drag pass, DA 750ft.
Old 10-18-2010, 06:38 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Be Honest
Be honest with yourself. How many times is it going to see 7,000 rpm. How many times will you load the engine to use 600 hp.
You're better served to have a slightly lower HP that is drivable that comes up a little short when you try to get to 6400 rpm than vice versa.
Are you gonna' race it or try to drive it on the street. Do yourself a favor - be honest.
my 2c
Paul
www.65shlb.com
www.prdcrrct.com
