Old 12-22-2010, 06:50 PM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Cam Plate question for 427FE
Which cam plate/retainer do i want/need for a 427 Shelby Aluminum block and where should i purchase it from?
Can someone please post a picture of the front of their Shelby block with the guts installed, but the timing cover still removed.
Thanks!
Old 12-23-2010, 08:39 PM
A normal FEplate - factory iron or Blue Thunder bronze - or aftermarket roller - willwork, although the clocking position is different. I'll try to get a pic for you - got one being assembled in the shop as we type.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 12-24-2010, 03:32 AM
Default Check the end play also
RestoCreations. Check the end play on the camshaft also with it installed in the block. If you are using a torrington bearing, this is real important. If the play is too much, the camshaft will walk around inside the motor and speed up the wear on the distributor gears and put extra stress on the distributor shaft and driving the oil pump. Rick L.
Old 12-24-2010, 08:29 AM
I just havent found a lot of the plates for sale on websites and that is why i wanted to ask here. That and the two types i have found have been roller and non roller and i am not sure if the roller plate is something that i really wanted or not.
Thanks for the replies! I apologize for my lack of knowledge in this area.
Old 12-24-2010, 10:35 AM
FWB's Avatar
FWB FWB is offline
here's a source.......quality parts...fresno Ca area.
http://stores.precisionoilpumps.com/...Categories.bok
fred
Fred B
Old 12-24-2010, 06:43 PM
I'll add a link with a pic of the BT part
