| 29 |
12-28-2010, 04:55 PM
AL
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Remote Oil Filter Adapter
Which remote oil filter adapter do i want for a 427 FE if I do not plan on running an oil cooler? Where is the best place to purchase?
12-28-2010, 05:22 PM
WV
I used this one. Large passages, excellent quality and price.
http://seamancustommachine.com/ford-...er-adapter.php
Rodger
12-28-2010, 06:50 PM
i used this one.....the machining was excellent
http://www.hylube.com/products/feadapter.htm
Fred B
12-28-2010, 09:15 PM
12-29-2010, 06:36 AM
AL
Thanks for the replies, but what i actually need is the piece that bolts to the front of the engine and holds the oil filter. I have not been able to find any close ups of the oil filter mount and how it attaches to the front of the engine.
While i am clogging up the FE forum a little more, what size - AN line do most run? It looks like around -12, but might be larger.
Thanks and i hope nobody minds me asking 9,000 trivial questions.
12-29-2010, 06:40 AM
va
12-29-2010, 07:18 AM
AL
Ok, thanks! Is that a good quality piece?
What size stainless braided line to most run? -12AN or???
Does the filter bracket bolt directly to the block?
12-29-2010, 07:25 AM
va
I have not used one of finishlines mounts but have not heard any thing bad about them, I make my own, real easy to make out of stainless or alloy. Mounts to water pump. I would go with -12 for better oil flow.
12-29-2010, 08:02 AM
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
I believe Kirkham sales a billet one you are looking for, ready to bolt up.
12-29-2010, 09:55 AM
Cobra Make, Engine: kirkham stroker 48 webers
Southern Automotive sells them
12-29-2010, 09:58 AM
Beware there are a couple different uppers floating around out there. One is finished in a flat gray and looks dirty after a short while under the hood. The proper one is a natural aluminum color and has a light satin sheen to it. I bought the later from Cobra Restorers in Atlanta.
