January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 02-06-2011, 01:42 PM
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
Default Motor/Bellhousing/Transmission weight
What does an aluminum block 427 with aluminum heads, clutch and bell housing, with Tremec 5 speed transmission weigh ready to drop into the car?
I want to extend my engine lift by 18" and need to check bending loads so nothing breaks...
Drink no wine before its time
Old 02-06-2011, 02:06 PM
Gonna be pretty close to 700 lbs....
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 02-06-2011, 02:20 PM
fordracing65's Avatar
Block weight: 120pds
Trans weight: 75 pds
Head each weight: 28pds
Bellhousing average weight: 24 pds
Clutch weight: 24 pds
Total engine weight: 600pds
These are estimates without fluids, got all the info by GOOGLE, works everytime!
PRIDEnJOY
Old 02-06-2011, 03:06 PM
Cobra Make, Engine: SPF 2592, Shelby alum. 527
If you're trying to drop the engine, etc. in from the front, an engine lift will easily reach if you remove one of the front wheels and position the engine lift at the side.
Rodger
Old 02-06-2011, 05:10 PM
A Tremec TKO weighs a tad over 100 lbs. A Quicktime bellhousing is the only one that's that light. If it's a Lakewood, you can double that weight.
You also have to remember the 70-80 lb crankshaft, rods, pistons, cam, etc. All of that adds weight in a hurry.
I'd say Barry's 700 lbs is going to be close if not on the low side.
I agree with Rodger....I've put FE/TKO combos in Cobras without having to do any engine hoist modification. It will go, no problem.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 02-06-2011, 06:03 PM
Tremcec t-5 trans weight: 75 pds. TKO 5 speed is 105 pds
PRIDEnJOY
Old 02-07-2011, 10:33 AM
Rodger
I will set up from the side. No hoist mods should be safer. Just not as convenient. Thanks!
