November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 09-13-2001, 08:03 PM
chuckbrandt's Avatar
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default Breather Question
I got this today from Branda. I bought it sight unseen and I must admit it wasn't what I was expecting. It is undeniably a beautiful piece. I'm just wondering if something like it was original to these cars etc? Will it fit under the hood? Wow is about all I can say
Secondly, if I have another breather on the oil fill tube, do I need any kind of breathers on the valve covers?
Thanks for any info,
Chuck Brandt
Old 09-13-2001, 08:23 PM
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
Chuck,
That breather does look great, but I opted for the more modern approach of a PCV valve in one valvecover and a K&N breather in the other.
This will keep oil contamination to a minimum and help avoid acid and moisture buildup inside the motor.
Later,
David
Old 09-14-2001, 07:03 AM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Chuck, I use that same setup on mine. There's plenty of room and it works just fine.
Old 09-14-2001, 09:30 AM
Club Cobra Member
Default ST - could you post a picture?
I'm wondering which way the S should point.
Thanks, Chuck
Old 09-14-2001, 09:47 AM
ST's Avatar
ST ST is offline
The breather is mounted so it clears the the carb. I'm using dual Holleys. There is a good picture of one on the E.R.A. site. Click on cutomer cars and on the second page there is a red Cobra with a couple of photos, one shows the engine compartment with the breather.
Old 09-14-2001, 10:55 AM
Club Cobra Member
Default Thanks - doesn't look as big on the motor!
I get it now, looks good.
Thanks, Chuck
