Old 03-21-2011, 12:21 PM
priobe's Avatar
Default recommendation of springs for MSD in 427
Hello all,
I am running the 2 light silver springs in my motor. I am thinking that this may be too soon for the advancement to come in.
I was thinking of using max 2 blues or a silver and blue.
Welcome to some suggestions. I am running Webers and notice a difference in sound at 2500 - 2800 in sound. But I am wondering if it is the main coming in.
This is also where the transition happens. Im thinking the sounds maybe a improper mixture at that rpm. It also happens to be highway speed cruising, so .. wondering if I can clean it up with timing?
Old 03-21-2011, 12:29 PM
I like the silver and the blue combo for Cobras and have used two light silvers before. If you keep the total advance at around 2400-2500 you should be fine.
Old 03-21-2011, 12:44 PM
I've done a bunch of experimenting, first with a 1x4 and now with my 2x4s. The sweet spot for my 427 is with two light blue springs, 18* initial and 36* total timing.
Old 03-21-2011, 04:49 PM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
I use 2 light silver springs in a MSD with a 454 FE single 850 QuikFuel carb. It runs like a raped ape off of idle.
Old 03-21-2011, 07:06 PM
RET_COP's Avatar
I settled for two light blue with a Black bushing. Advance starts at 1500 rpm and is all in by 2500 rpm.
Lou
Old 03-22-2011, 01:48 AM
I do a lot with the silver and blue & black bushing...
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
