November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-01-2012, 05:12 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Question fe v belt question
i was wondering if any one would have a part number fora a v belt for a fe?.
i have the following
1) edelbrock 8805 waterpump
2) march 1552 waterpump pulley 6 inch
3) PROFESIONAL PRODUCTS SFI 9000 BALANCER WITH SINGLE GROOVE PULLEY BELIEVE IT IS A 7 INCH PULLEY
4) PA PERFORMANCE 95 AMP 3 G ALT WITH 2 11/16 V PULLEY
5) SHELBY ALT BRACKETS.
Old 02-01-2012, 05:32 AM
I think mine should work for you.
Old 02-01-2012, 05:49 AM
Question
patrickt, i noticed in your picture that it appears your only running the top alt mount is this true if so is there no need for the bottm mount?.
Old 02-01-2012, 05:54 AM
I cropped that shot for a better view of the Gatorback belt. You need a mount at the top and bottom. Here's the full pic:
Old 02-01-2012, 05:58 AM
so you are just running the bolt and spacer to the block and not the bottom mount that mounts to the waterpump?.
Old 02-01-2012, 06:04 AM
Right. The alternator just rotates around the bottom bolt, with the bottom bolt acting as the mid-point of a circle. The top bracket is the portion of the circumference of the circle that tightens up the belt by adjusting the total distance from the water pump and balancer pulleys. Super simple design.
Old 02-01-2012, 06:09 AM
good to know that cleans it up a bit, thanks for the part number now i can go into a parts store with a actual number, alot of times if you just have a measurement they dont know how to cross ref. the good year site shows it as a 45.500 with a top width of 0.44
Old 02-01-2012, 06:28 AM
Now I do run a simple brace over to the bottom water pump bolt for a little added support. Here's a better shot of it (this was taken when I was replacing my old POS balancer with a nice new ROMAC balancer, that's why it's different):
Old 02-01-2012, 06:42 AM
here is a picture of my 445, i just painted it last week it is still at the engine builders, i am ready to take it home i was just looking at the water pump and allternator to see what else i need.
Old 02-01-2012, 06:52 AM
Personally, I really like the old surge tank look. Remember if you mount your ignition coil any way but straight up and down get one that is not oil filled else it will cause intermittent shorts and drive you up the wall.
Old 02-01-2012, 07:36 AM
Cobra Make, Engine: Shell Valley Cobra Kit -428 Fe Built by Clayton Racing Engines
I would not run the underdrive pulleys on your FE , you run the risk of poor water flow at slow speeds and as well as to slow of the alternator. I called March about this problem because it is a problem and they know about it : but there is know warning on the box or there ads. I ask them why they did not make it clear , there answer was it is for RACE APPLICATION ONLY. I had a machine shop make a custom pulley to match the March pulleys a full 7.25 inchs , problem solved . .
Old 02-01-2012, 04:00 PM
Question
i like the look of the old surge tank to, i have one my problem is i have a ron davis radiator the outlet comes out the side and makes a 90 i have a degas tank that mounts to the passenger side f panel the hose runs inside the upper fender well. i have the msd blaster 3 coil. my other issue is the canton oil filter adapter on the factory five you have to run the short oil filter because of clearance issues with the 4 inch round frame tube. i would like to get the remote set up and move the filter to the front.
i run underdrive pulleys on my 342 since 2005 never had a issue will that little difference in pulley size really matter?.
Old 02-01-2012, 04:49 PM
Yeah, it can. BUT, I would just put the pulleys on that you have and wouldn't think too much about it. Just remember if you have a heat load gain problem at idle you'll know the first thing to change (and swapping pulleys is a twenty minute job).
Old 02-01-2012, 07:08 PM
Bulletbrown .... not going to argue on the under drive pulleys as every case/engine is different , but I`ve been running the March under drive units on my 482 for over two years with no overheating issues ... both on and off the track . At VIR last summer , I saw 190 to 195 on the track and 195 to 200 sitting on pit road . Around town , I normally run 180 to 190 when moving and up to about 200 sitting still . This is with ambients at upper 90`s to low 100`s down here . However , there were some things done that most people won`t do , or caution you to not do . Since Robert Pond built the engine and said this was what should be done , that`s what I did .
If it ever does become an issue , I`ll just up the idle speed with my right foot when stopped .
Old 02-02-2012, 04:23 AM
Default Wrench 87 easy why
Wrench87 Get your pulleys and brakets on the motor. Then get a piece of nylon rope and have it go around all the pulleys. Hold the to ends togeather with the adjustment for the alt 1/3 from bottom. Measure the rope and you have the correct length of the belt. First 2 numbers are width, last 3 numbers are length with 5 number belts. The other thing is making sure that the pulleys are inline. With the rope check for this too, if not, it is easier to do this with the motor outside the car. Rick L.
Old 02-02-2012, 05:13 AM
hi rick, i know how to measurethe belt like you suggested but i think it is easier to have a part number so the parts guy can cross reference.
it is hard to find good parts guys these days they have to fill in all the blanks that the computer screen asks them. i went to rock auto and looked up a 72 f 100 with a 390 and they must have listed 20 different belts different manafacturers and different set ups, now i have a starting point.
Old 02-02-2012, 08:19 AM
Avmaviator's Avatar
Cobra Make, Engine: Kirkham #647 brushed
Wrench87
I just went through that process a couple of months ago. I tried the string/rope way and ordered a belt from Summit. It came out short.
So I just went to Napa and got three belts of different sizes, went home, took me a minute to find the corredt on, then returned the other two... Pretty easy that way.
