Like Tree4Likes
Old 05-01-2012, 06:57 PM
krkucin's Avatar
Cobra Make, Engine: Superformance #1962, 427 SO
Default Type of oil in 427 S/O
What are people using for oil in their 427 side oilers? Regular, synthetic or a blend? Thanks!
Old 05-01-2012, 07:04 PM
jwoodard's Avatar
Thumbs up
I run Castrol 10W40.
Cobrags likes this.
Jim Woodard
Old 05-01-2012, 07:15 PM
Unless you have a solid flat tappet cam, there's not a whole lot of difference, that really matters, so long as you have the right viscosity. There is anecdotal evidence that synthetics leak more in FEs that non-synthetics (some report that switching to a synthetic brings about leaks that didn't exist before). Personally, I use Brad Penn.
Old 05-01-2012, 08:11 PM
I have run both Brad Penn 20W-40 and Valvoline VR-1 Racing straight 40W. Seems like the VR-1 stays clean longer. Only dinosaur oil for my dinosaur engine.
Old 05-02-2012, 04:22 AM
Default 15-40W rotella and oil suppliments
Been running 15W-40 rotella diesel oil for years. I have a hydro roller motor. I also run 1 bottle of either EOS oil suppiment or Lucas oil additive. HVHP oil pump with #100 spring. Have a accusump to start motor, no dry starts. Let motor run for 1-2 minutes without any change of throttle until some heat is in the oil and the pressure comes down to under 90 psi off idle. Any good oil will work but remember that they have removed alot of the Zinc and Ph. to help with wear and tear on the internals. Rick L. Ps I don't believe in syntheics for the extra cost in track cars. Also not looking for every extra HP I can find.
cdnus likes this.
Old 05-02-2012, 11:46 AM
Have any of you guys tried the Joe Gibbs Hot Rod HR1 oil???
Since I am running in a fresh engine with their break in oil, I figured I would try it after 500 miles of their BR1 oil.
Old 05-02-2012, 11:57 AM
Joe Gibbs is good stuff, and maybe a little pricier than Brad Penn. The only complaint I have with Brad Penn is that it's green. Yeah, yeah, I know it sounds kind of cool, and maybe it is, but small puddles of fresh coolant look just like Brad Penn to me. I had just changed my oil a couple of weeks ago and when I looked under the car a few days later there was a small, maybe three inch wide puddle of what looked exactly like the Brad Penn I had just put in her. So I wiped it up, tried to figure out where it could have come from (filter, "splash," maybe the copper crush washer was all used up...) and dismissed it, figuring if it was anything other than splash that it would reappear. I did "sniff" it on the off chance it was coolant, but detected no odor... and since it was dripping right from the back of the pan, I was sure it was Brad Penn. Well, it wasn't, and I found the source of the coolant leak shortly thereafter. Of course, every leak on an FE trails to the back of the engine and looks like an oil leak (usually like the rear seal)... even coolant leaks. I would prefer it if the Brad Penn was not the color of my coolant.
Old 05-02-2012, 12:30 PM
LOL Pat. Green oil. Could get confusing really quickly.
Prior to freshening up this engine I always used VR1. Never had a problem, but their newish packaging is confusing and I believe the zinc levels are way down compared to when I originally built this engine.
Old 05-02-2012, 12:35 PM
FYI zinc levels in VR-1 same as always, click here for specs.
Old 05-02-2012, 01:14 PM
RodKnock's Avatar
I use Joe Gibbs Conventional Hot Rod oil. Works for me. No issues.
Old 05-02-2012, 01:23 PM
Stentor's Avatar
Same here--I've had good luck with Joe Gibbs HR oil.
Old 05-02-2012, 03:19 PM
Bernica's Avatar
Senior CC Premier Member
I am running Joe Gibbs synthetic XP3. Pricey, plenty of ZDDP. So far, no issues. Pressure seemed more stable and seemed to run a little cooler, but maybe that's just me...
Old 05-02-2012, 05:04 PM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Thumbs up
I go with what Lee Holman suggested for my FE; 40W! I use Brad Penn.
Old 05-02-2012, 05:38 PM
Cobra Make, Engine: Superformance #1723-427 Windsor
Joe Gibbs 10/30 synthetic hotrod oil for average climate is the best.
Old 05-02-2012, 07:17 PM
FWB's Avatar
FWB FWB is offline
Brad Penn only
Fred B
Old 05-03-2012, 07:27 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Keith Craft said to use regular 10w-40. That's what I use. Castrol 10w-40.
I go by what the engine builder suggests......
Old 05-03-2012, 08:51 AM
Stentor's Avatar
Craft has changed his tune on this. He now recommends Joe Gibbs.
Originally Posted by Keithc8 View Post
We have used about every oil possible. We will only warranty our engines if Joe Gibbs is used. If you look at the facts it has more ppm zinc and less ppm detergent than most any other oil. Try to stay away from most all oil that you can buy through a regular parts store. Those oils have to meet the lasted epa standards which have taken most all zinc out and added lots of detergents. As you well know zinc is what bonds the oil to the metal and the high ppm detergents wash the zinc away. This works great for late model stock engines with overhead cams and low spring pressure. Bottom line, make sure there is plenty zinc in the oil to save problems in the future.
Old 05-03-2012, 10:13 AM
krkucin's Avatar
Regular? Or synthetic?
Old 05-03-2012, 10:17 AM
I think all of the oils of the Brad Penn/Joe Gibbs type caliber are now touted as being "partially synthetic." I know that's true of Brad Penn, but I don't really know what it means. It's kind of like being "partially pregnant."
Old 05-03-2012, 10:29 AM
My Builder said to go with conventional 15/50 Gibbs.
He is a High Flow oil type of builder. Builds a ton of Roundy Round engines too.
