Old 06-24-2012, 08:36 AM
Default Installing A FE
Questions about angle of carb pad when installing engine...should the carb pad be level or do you use the valve covers or crank?? I'm using a RPM Intake.
Jon
Old 06-24-2012, 10:12 AM
FWB's Avatar
FWB FWB is offline
jon, you won't have much wiggle room, from the trans to the rear, i would be sure of the pinion angle first, you may not have much choice
Fred B
Old 06-24-2012, 10:28 AM
Default Motor height
Fred, lowering the motor 3/4" which is solving a hole host of problems and cutting the bottom of the bell housing to recapture the ground clearance. I have the motor in and it is level at thecarb pad but after looking at the spec's of the RPM which leans forward I was wondering if that was correct?pinion angle looks ok and I do have adjustable arms on the rear.
Jon
Old 06-24-2012, 10:50 AM
FWB's Avatar
FWB FWB is offline
historically the carb pad is angled forward slightly,
i would install so the block is level, use the crank or the front and back top rails as a guide if the intake is off...
Fred B
Old 06-24-2012, 11:18 AM
DanEC's Avatar
Can't really compare between different kits but I just installed the motor in my ERA and the carbs tilt forward 3 deg with the transmission height set for the rear end. If you are running a 9 inch Ford rear that may really change things up with the dropped pinion location.
Old 06-24-2012, 11:36 AM
FWB's Avatar
FWB FWB is offline
factory intakes had a 5 degree carb pad angle
Fred B
