Old 08-02-2012, 10:57 AM
Default FE/Manifold Location PCV
I have a Blue Thunder intake manifold on an FE 482 block and have to install a PCV.
The question is, where is the best place to route the PCV line coming from the passenger side valve cover.
I will be using an Earl's alum breather on the drivers side valve cover and an Earl's alum breather with integral PCV/an-6 on the passenger.
** There is no rear carb port and I dont have the hood clearance to add a carb plate, even a Boss 302 style.
So I have 2 options:
Do I use the plug on the manifold underneath the rear of the carb...........or drill and tap the cover plate (covers the 1 1/2" rear port - currently has the 5" high FE breather on it) for the fitting.
Additionally, if I use the smaller hole below the carb should I reinstall the rear manifold cover plate to increase vacuum, or can I leave the breather on?
Sorry for the long question, looking for someone who knows or who has already done the experiment so I wont have to, thank you.
Best, Bret.
B. Ewing
Old 08-02-2012, 11:20 AM
Clois Harlan's Avatar
If you really have to run a PCV valve I would just use the port in the back of the carb. Then after inspection you can take it off and re-tune your car.
Clois
"Let's roll"
"Be part of Something Good
Old 08-02-2012, 11:29 AM
Hi Clois,
The port is on the mainfold about an inch or so below the carb. This is on a cobra so, happily, no inspection!
This will be a permanent installation to keep oil vapor from covering my valve covers. I dont really like the look of the puke tank and I'm not crazy about the road tube idea.
Just looking at which option is best.
Best, Bret.
B. Ewing
Old 08-02-2012, 12:36 PM
Different than yours but the idea's the same.
Summit billet PCV / Moroso baffled grommet / 3/8" hose / an hours worth of work.
Chas.
Old 08-02-2012, 12:43 PM
Ah ha!
That makes sense, that PCV is at the same atmospheric potential as a valve cover (with PCV) would be.
So do you have an "open" oil fill tube or a breather on the drivers side valve cover?
Bret.
B. Ewing
Old 08-02-2012, 01:24 PM
Oil fill tube. Works perfectly, leaks go away.
Chas.
Old 08-02-2012, 01:29 PM
Yep, I've heard the same. Thanks a bunch for the info.
Best, Bret.
B. Ewing
Old 08-02-2012, 01:42 PM
That ain't how your leak "went away."
Old 08-02-2012, 02:11 PM
I meant leaks that the DEVIL Hissef didn't cause.
Chas.
Old 08-03-2012, 05:22 PM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Wink
I was having the same problem with oil blow. I used ERA Chas's recomendation & it worked wonders! Hope you have the same luck!
Old 08-03-2012, 06:40 PM
FWB's Avatar
FWB FWB is offline
i left the 5" high breather tube and ran the PCV to the hole in the back under the carb,
you could plumb it with steel tube for a cleaner look
Fred B
Old 08-03-2012, 07:35 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Hi Bret,
I have a Blue Thunder intake on my 428. I have attached a couple of pictures of my set-up, including the basket filter under the PCV valve. My manifold is off the car right now as I am in the process of changing my intake manifold. Hope this helps.
Old 08-04-2012, 07:49 AM
lovehamr's Avatar
Stolen Avitar
I tried running mine almost like M930's except with a PCV valve located in the intake, using the little steel wool basket and all. I got oil in my intake all the time. In searching for a way to keep the PCV and not dump oil into my intake, this is what I used. It's not small but hardly anyone notices it tucked back there at the back of the intake. This is an air/oil separator from Moroso. Since using this setup I haven't had any oil in the intake (or on the valve covers) and I only get about an oz of oil out of the drain after a hard day at the track or a few weeks of street driving. This is how I did it.
Old 08-06-2012, 07:18 AM
Thanks to all!!!
You guys are great, what a brilliant bunch of gearheads.
We now have a plan.
Best regards,
Bret.
B. Ewing
Old 08-06-2012, 07:27 AM
FWB's Avatar
FWB FWB is offline
Bret, the plates you see guys using, mostly are dove cast ones, or made up custom.
i keep these in stock, plain not drilled for a grommet. machined from solid alum, not cast.
i'm 15 minutes north of you up 7th st. if you want to see them.
there is also an old for sale ad with pics. have about 30 in stock.
Fred
Fred B
Old 08-06-2012, 09:19 AM
Fred
Fred,
You are close, suprised we haven't run into each other.
I actually have an aluminum block plate, not sure if its Dove or not, but its a nice cast piece.
Great to have yet another valuable resource close to home, thanks Fred! I'll tell the Boyz.
Best, Bret.
B. Ewing
Old 08-06-2012, 10:09 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by bret a ewing View Post
Fred,
Best, Bret.
if i remember correctly your on the southside......i don't get over there often, hehehe, we are separated by that "little Newark" Allentown.
always here though, if you need a cruise to destination, stop in....
Fred
Fred B
Old 08-06-2012, 10:17 AM
I'm in Ballietsville, near Schnecksville, maybe a half-gallon of race fuel away.
Nice work on the plates, first rate.
Bret.
B. Ewing
Old 08-06-2012, 10:25 AM
FWB's Avatar
FWB FWB is offline
oh crap.....my mower guy is a stones throw from you, right by the ballietsville inn.
i'm 500 feet from the treichlers bridge.....hell, your 5 minutes away...
Fred B
Old 08-06-2012, 10:29 AM
Crawled home many a night from "The House of Phil", (Villa Lentini)
............OK, make that a gallon of race fuel.
B. Ewing
