Like Tree1Likes
LinkBack Thread Tools Rating: Thread Rating: 7 votes, 4.14 average. Display Modes
Old 10-21-2012, 07:37 PM
Originally Posted by BAsque1 View Post
I tried to get a serious answer and possible viable solutions and instead I feel I have been ridiculed.
I gave and showed you the serious answer Lou. The humor was meant to show you you're overthinking your needs. Was not ridicule. It's humor with thought behind it-which escaped you.
From your post #8:
"(I know I will be roasted by this but...I can take the heat---no pun intended)"
Well if that's true, lighten-up and realize that you've been shown an effective way to solve your problem, and economically as well. Strange way to say 'Thank you for a viable solution and posting a picture'.
If you want a serious fix, work on it. If you want a T-pan to wow them in the parking lot like the other posers, ignore with all haste. Whining won't fix anything.
Chas.
Old 10-21-2012, 07:42 PM
Originally Posted by Dimis View Post
As for the old married couple bickering amongst themselves in the corner, don't mind them, just consider it side entertainment.
It's not side entertainment pal-it's a well thought out and fabricated fix to a problem-that's been functioning for decades. Don't diminish serious help as idle banter.
Chas.
Old 10-21-2012, 08:35 PM
Dimis's Avatar
Haha...
Stop jerking the poor guy, wise guy.
Lou, unless you're racing Erica Enders next week looking for a 6.50, forget that crap. It'll look like a shop vac on a soft motor-or ANY motor...
Pulling cold air and isolating heat is simpler and very effective. Vent whistles in the bowls help avoid stalling too.
Just do this:
Some of it - Yes. For that, I thank you!
Now I know how you got to two roll bars-you started with plastic (inner) fenders.
However other parts, not so much, but alas I thank you again. It gets a laugh out of me every time...
Either way, its worth the price of admission
...and apologies I find you both so entertaining
Old 10-21-2012, 09:18 PM
RodKnock's Avatar
You know I don't know who to believe... I tried to get a serious answer and possible viable solutions and instead I feel I have been ridiculed. This is not the purpose of these forums!!
Have a wonderful day
601HP likes this.
Old 10-22-2012, 11:30 AM
BAsque1's Avatar
I understand that a joke is a joke but when someone is trying to fix a very frustrating problem somtimes the jokes should come to an end. I appreciate those who gave me what they thought was serious suggestions but... lets leave there.
Basque1(Lou)
Old 10-22-2012, 12:04 PM
Lou, just tune that goofball Chas out -- RodKnock too. If I had a nickel for every time they pissed over a serious thread..., ahh nevermind. Seriously, if you're having heat soak problems, whether they be in in the lines themselves or in the carb, having your fans run a little longer when you shut the car down will make a big difference. Do you have your fans on a thermo switch? If so, where is the switch and what's the triggering temp? Do you have a fan override switch? What you might try as an experiment is to run your car in a fashion that usually creates the problem, shut it down, and when the fans automatically turn themselves off throw your override switch and run the fans for three minutes longer. Then see if you still have your heat soak problems. If that does the trick then there are easy ways to make your heat soak problem go away. Unfortunately, those tricks will not work on Chas.
Old 10-22-2012, 12:59 PM
OK I'm done here. Lou-don't fear- I will never sully your posts again with an attempt to help you. In doing so, I apparently offended your sensibilities-probably because you can't comprehend the analogy I used. It was clear common sense but you couldn't see past what you didn't understand.
Are you related to a guy named 'Rsimoes'?
Unlike about 14,000 other members, I did post a serious attempt to help you and a photo too. You still don't get that. Won't happen again.
Counselor-your version of good cop / bad cop? First you scam the guy, then you 'help' him. As Bogie once said, "You're good."
Resume holding hands.
Chas.
Old 10-22-2012, 02:06 PM
RodKnock's Avatar
Chas knows his stuff, surely listen to him.
But I do agree with Patrick that you should definitely tune me out. I really have nothing to offer this forum other than my good looks and personality.
Old 10-22-2012, 03:10 PM
rpatton3's Avatar
Default Slide show for Backdraft 874
You don't see Turkey Pans on small blocks all that often. Russell, would you post a pic or two, please?
Slide Show for album :: Backdraft #874
I think there are 126 photos. I have been trying to make a PowerPoint show and show you just the turkey pan. I believe photo #111 is first one of turkey pan.
This is sorta like seeing your neighbor's home movies, but it is in there, near the end 111-120 or so.
Try pages 6 and 7.
Russell
Old 10-22-2012, 03:20 PM
It looks quite nice.
Old 10-22-2012, 08:11 PM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Thumbs up
Basquel, rather than spend money via Summit. I wen't to local hardware store & bought (1) A 2' piece of 3" galv. dryer vent (2) 0ne 8' piece of 3" flex(sprial expanding type) alum. dryer vent line. (3) One 50' roll of 2" wide quality alum. sheet metal (basicly heavy guage alum foil with adheavsive on 1 side) sealing tape. (4) Two 45 degree 3" dia sheet metal tee's (5) Eight 3" S.S. pipe clamps. I then cut/fit the strait 3" vent pieces to the desired locations on the turkey pan. One for each side, I secured the vent pipe to the T-pan via the alum. seal tape. I then installed the 45 degree tee's into the 3" fresh air vent lines. Then; cut, fit & installed the 3" flex vent between the tee's & the pan openings. As to the foam sealer between the pan & the hood. I cut/fabracated a 1"W x 1/8" thick piece of alum plate to bolt to the top lip of the t-pan. This way I can change/remove the foam stripping from the pan any time I wish. As the tape has a very high shine factor. The overall job came out looking the balls! I did all this while the t-pan was still mounted on the engine. It took about 4 hours. I would suggest that you have some good quality sheet metal tin( L,R, & S cut) snips. a hand held sheet metal flange srinker. they look like tin snips but create the wrinkled flange end needed to fit on flex/strait vent pipe. & other assorted tools. Also, insure no metal shavings go where they don't belong! I hope this helps M8! Enjoy! Oh yeah, I spent about $40 bucks on materials.
Old 10-22-2012, 09:07 PM
rpatton3's Avatar
Thanks for getting a single shot from the 126 slide show. Obviously, you have superior computer skills. Way better than mine.
  #33 (permalink)
Old 10-22-2012, 09:13 PM
rpatton3's Avatar
Thanks for getting a single photo from the slide show.
Thank goodness, no perculation problems in Arkansas. We have plenty of clothes pins just in case!
Russell
  #34 (permalink)
Old 10-22-2012, 09:22 PM
rpatton3's Avatar
Default Turkey pan on 427 Roush small block
Thanks for this interesting forum.
  #35 (permalink)
Old 10-23-2012, 01:32 AM
Dimis's Avatar
This is just plan false! ...and a lie!
You offer this forum more than just "good looks and personality"
  #36 (permalink)
Old 10-23-2012, 04:36 AM
... not to mention his seemingly unending cash reserves.
Lou, one last point. When I start my car after it has been sitting cold for a week or two, I pump the throttle twice, turn the key, and she starts just like a bomb going off. BUT, and this is a BIG BUT, if the car has been driven at all that day, and I touch the throttle, the car will not start. What I have to remember to do is just turn the key, and not touch the throttle -- and she starts every time. Unfortunately, about once a summer I forget and hop behind the wheel of a hot car and pump the throttle. When I do, I now don't even bother turning the key. I just get out, go back in to the oyster bar, and give it a while. Chances are you knew this tip, but I thought I'd pass it along anyway. And if Chas writes any comments to this post, just ignore them.
  #37 (permalink)
Old 10-27-2012, 08:12 AM
BAsque1's Avatar
Patrick:
I already sifted out the serious and the jokes and I realized who is saying what.
I am intalling an electric gas pump which will have an in line oil cooler adapted to cool the gas. I addition I will increase the diameter of the air filter with a flow through KN air filter. I already installed the phenolic spacer and hopefully I can leave the turkey pan on.
If it persist with the percolation, then the Turkey pan comes off. The fans in my car kick on @ 200 degrees I can leave them on until they temp goes down that's not a problem.
I will also install throught the front vents two cooling hoses with inhose mini fans to add more cool air to the engine bay. I have realized that there are some quirks that these cars have that we need to live with them or buy a Corvette(thar's not going to happen)
Thanks for your advise, take care.
Lou
  #38 (permalink)
Old 10-27-2012, 08:45 AM
Obsessive's Avatar
Cobra Make, Engine: Shelby American, 1965 427 FE, alloy MR heads, Sidewinder intake
Patrickt,
Where did you get the K&N top portion of your air cleaner in this picture? I've looked for these without success. Thanks!
  #39 (permalink)
Old 10-27-2012, 09:18 AM
Obsessive's Avatar
Strike that. I just found it! K&N Air Cleaner Top
  #40 (permalink)
Old 10-27-2012, 11:07 PM
rpatton3's Avatar
I think the grille splitter was only on street cars. RUMOR has it that the air was deflected up to create downforce, but it doesn't look like it would help much on that.
The splitters are probably supposed to divert airflow under the hood.
This guy has an adjustable and a fixed version.
Dark Water Customs | Shopping Cart
I would like one myself; his brackets are not made for Backdraft roadsters. They look like they could be adapted to just about any grille opening.
The air deflection might solve the percolation problem and set off your car's appearance, too.
Good luck.
Russell
