Like Tree3Likes
  #41 (permalink)
Old 03-30-2013, 02:43 PM
Well now, if "posts per year" is any benchmark of savvy....
  #42 (permalink)
Old 03-30-2013, 02:45 PM
Bernica's Avatar
Senior CC Premier Member
Thanks Chas. I am out. Good luck Mike.
  #43 (permalink)
Old 03-30-2013, 04:37 PM
Bernica's Avatar
Really?... Really? Someone has the time to figure out how many post per year? Nice one. I guess nobody has anything else to do or say.. Again, best luck to Mike.
  #44 (permalink)
Old 03-30-2013, 05:20 PM
My point was that Chas is always ragging on me for my 14,000+ posts, most of which is miscellaneous drivel. You really just have to ignore Chas. He irritates everybody, but he does so with no real malice, just crustiness.
  #45 (permalink)
Old 03-30-2013, 07:02 PM
Oh in YOUR case it's real malice-AND forethought!
Chas.
  #46 (permalink)
Old 03-30-2013, 07:05 PM
That's aforethought, with an "a" in front of it.
  #47 (permalink)
Old 03-31-2013, 12:55 AM
Eljaro's Avatar
and in the meanwhile Mike is still trying to figure out where his oil pressure is going
  #48 (permalink)
Old 03-31-2013, 06:03 AM
You solved it with the pump discovery, didn't you?? Still low hot pressure???
plissken likes this.
Chas.
  #49 (permalink)
Old 03-31-2013, 06:22 AM
Used as a noun, either is acceptable-
Ron-WHERE is that 'LOATHE' button I begged you for????
Chas.
  #50 (permalink)
Old 03-31-2013, 06:47 AM
Or maybe just a half-button.... Because, you know what they say, half a loathe is better than none.
  #51 (permalink)
Old 03-31-2013, 07:17 PM
Cobra Make, Engine: Hurricane Cobra - Keith Craft 428 stoker, 600 HP/614 Trq
Send a message via AIM to COACH MIKE Send a message via Yahoo to COACH MIKE
Default FE aluminum block oil pressure
I took the cobra out again and warmed to operating temperature. Oil pressure was around 20 lbs at 1100 rpms and responded quickly to rpim increases. 40 to 50 lbs between 2,000 and 2,500 rpm, up to 60 quickly at 3,000+. 60 lbs plus at anything approaching 4 to 4500 rpm. Spoke with Keith Craft and he assures me this is the tendency with the aluminum blocks he builds. If there are any problems he will take care of it. I have every confidence in Keith since I have had two other engines from him and they have performed flawlessly. Also, have two other friends with engines built by Keith and have had no issues with those engines either.
I appreciate everyone's input. Always intersting to see the wide variety of knowledge available on club cobra.
Coach Mike
  #52 (permalink)
Old 03-31-2013, 07:36 PM
Took the cobra out again yesterday and warmed to operating temp. Oil pressure response quickly with any increase in rpm's. 35 to 40 lbs at 2,000 rpm, 45 to 50 quickly at 3,000 + and 60 lbs to 70 at 4500 and up.
Keith Craft explained this was typical for his aluminum block builds. If there are any issues he will take care of it. I have every confidence in Keith. I have had two other engines he built with no problems and very good performance.
Also, two friends he has built engines for with the same good reviews.
Thanks for all the information. Very impressive the wide variety of advice available on club cobra. Much appreciated.
Coach Mike
  #53 (permalink)
Old 03-31-2013, 07:40 PM
Sorry for the double reply. Thought the first one got kicked off and tried to remember exactly what I posted. Again, Thanks much. Will see how it runs down the road.
  #54 (permalink)
Old 03-31-2013, 08:35 PM
Bernica's Avatar
Congrats Coach Mike. Sending you a PM.
  #55 (permalink)
Old 03-31-2013, 08:49 PM
Gaz64's Avatar
"That's a forethought" is correct grammar Patrick.
Forethought Synonyms, Forethought Antonyms | Thesaurus.com
  #56 (permalink)
Old 04-01-2013, 05:50 AM
That one is a hoot!
You two are whacked!
  #57 (permalink)
Old 04-01-2013, 06:04 AM
Since aluminum grows more than iron, to have the same hot idle pressure, an aluminum motor will need to have tighter main bearing clearance when cold. The tighter main clearance can reduce oiling to the rods until proper temperature is reached. It's not uncommon to build aluminum blocks to have a little more clearance on the main bearings. This prevents then end user from kicking the rods out when he stands on a cold motor. As long as pressure comes up on throttle, all is well. Every aluminum race engines I've owned was built this way.
  #58 (permalink)
Old 04-01-2013, 04:16 PM
A book I have on the 4.6 ltr modular said the main clearance on the aluminum block is under 0.001" when the temp is below zero. (This is based on my memory of reading the book). The author made a fairly big point that owners need to be very careful keeping the rpm down until the engine warms up.
I'm sure the bearing gap increases with temp on both the mains and the cam. No doubt in my mind that an aluminum engine would see a greater drop off in oil pressure, when warm, than an otherwise identical iron engine.
  #59 (permalink)
Old 04-01-2013, 04:23 PM
I set aluminum block main bearing clearances pretty tight on FE's...usually around .0018"-.0020". Taking into account that the clearances open up anywhere from .00075-.001".
Rod bearing clearances are the same as an iron block. Cam bearings get the green loctite treatment.
Lash also grows a lot more with an all-aluminum combo. Iron blocks with aluminum heads get .006" tighter lash when cold as a starting point. All aluminum engines get .010" tighter.
  #60 (permalink)
Old 04-01-2013, 06:15 PM
Cobra Make, Engine: jbl
that same book says the mains grow .002".
