Like Tree2Likes
Old 07-19-2013, 08:13 AM
Default New bullet for CSX3170
I lost a roller lifter (axle broke) at the Laguna Seca 50th anniversary Cobra event last year and the rebuild was just completed at Kinetics Racing Engines in Michigan. The new engine has more compression, a cam with more high lift duration, lighter pistons, a much lighter crank, and increased head flow. My goal was to increase top end horsepower and decrease low end torque to help control wheel spin.
Excuse Section: The temperature and humidity in Michigan have been horrendous this past week so my dyno numbers were not what I had hoped for. Although there is an SAE correction factor it seems to project worse numbers when conditions are bad and optimistic numbers when the factors are negative (cold air and good barometric pressure).
To put things in perspective Kinetics recently dynoed a Robert Yates Cup engine that was 850 hp at Yates Shop, the Kinetics dyno showed 805 hp with a peak torque of 566 lb/ft. This was done under much better conditions than we had yesterday. Our inlet air temperature was 89 degrees F with a vapor pressure of .92 . 3170's new bullet made 827 hp @7500 with a peak torque of 642 lb/ft at 5500. Average horsepower from 5500 to 8000 was 764 and average torque was 598 lb/ft from 5500 to 8000, not too bad for a normally aspirated 1950's truck engine. Kinetics estimated that the engine would have a corrected number of around 850 hp under conditions closer to a 0 correction factor.
Next step, install it in the car and put the race suspension back on, should be running sometime in August.
LoBelly likes this.
Old 07-19-2013, 08:16 AM
LMH's Avatar
LMH LMH is offline
Wow! Ok, we are going to need video on this one!
With sound!
Alba gu brąth
Old 07-19-2013, 08:47 AM
Rick Parker's Avatar
Nice job "B"!
Rick
Old 07-19-2013, 09:08 AM
Very cool parts selection Bruce. What do the heads flow at .600 and above and what is the new displacement?
Chas.
Old 07-19-2013, 09:13 AM
gsharapa's Avatar
Bruce.....how does that compare to your old engine you were running?
Gary
CAV GT40
Old 07-19-2013, 09:57 AM
philminotti's Avatar
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
Wow. Over 800 hp from a normally aspirated FE? Is this a cammer? For a wedge head motor, that's startling even if it were a 527. Details would be appreciated
Old 07-19-2013, 10:49 AM
Default Engine comparison
The old engine made 807 under conditions that were close to optimum, when I redynoed it under similar conditions (hot weather and humidity it made about 760 peak and 640 lb/ft.
Head flow is 380 at .800 don't know about .600, ex about 265 the engine is still 498 cid. The big difference is it pulls all the way out the back door where the old one fell off dramatically above 7600. I won't do this but Kinetics said an 8500 shift point would be about right. We took 5 pounds out of the crank and lightened the intake valves (titanium in and ex) along with much better valve springs. I wanted 400 cfm but we could not get there with out sliding the heads over ala Barry R. and I did not want too redo headers and intake so we stopped here. It should be a real animal in the car, the old one was scary on 7 cylinders.
ERA Chas likes this.
Old 07-19-2013, 10:26 AM
mickmate's Avatar
Sounds like a beast Bruce, does this mean I'm back to the passenger side?
mickmate
http://www.actoncustom.com/
Old 07-19-2013, 02:49 PM
Default Passenger Seat
Hey Nick,
I don't know of many people that would want to sit there but you are welcome
to.
Old 07-19-2013, 11:03 AM
Jes yer average 1.7HP / CI, 50 year-old moder.
Chas.
Old 07-19-2013, 02:51 PM
Cobra Make, Engine: Backdraft, SBF 351w (463 CI)
Well done Bruce.
Old 07-19-2013, 03:23 PM
gsharapa's Avatar
Can't wait to hear and see it run so make sure you get some video uploaded for us~~
I thought mine was a hand full at 682HP can't imagine another 180 HP....
Gary
CAV GT40
Old 07-19-2013, 05:03 PM
fordracing65's Avatar
I have been following this thread, and this new engine seems extremely to dangerous. I think you should give me the car for safe keeping, and you can borrow it, from time to time...
PRIDEnJOY
Old 07-19-2013, 02:33 PM
Really, really cool piece!
The guys at Kinetic know their poop...
Your heads are very, very close to my EMC high risers in flow - those are based on BT high risers - Chris G has flowed them and can share the data. I have only seen two FE heads that went to 400, and both of those were BT high risers with every trick in the book. that's a long way of saying that yer boys done good!
You have the highest power non-drag race N/A FE that I am aware of anywhere. Very cool indeed.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 07-19-2013, 02:44 PM
Default FE engine
Thanks Barry,
Getting the engine to fit under a stock Cobra hood does restrict things a bit
in the flow department
Old 07-22-2013, 01:21 PM
xlr8tr's Avatar
Cobra Make, Engine: CAN-AM cobra, 460 SVO
I think you had issues keeping the old mill under noise limits: anything new to keep this one quiet enough?
Mark
Old 07-22-2013, 01:27 PM
Originally Posted by xlr8tr View Post
i think you had issues keeping the old mill under noise limits: Anything new to keep this one quiet enough?
850 HP with a 1" roller cam. :lol::lol::lol:
It may not be louder than his old 750HP...
Chas.
Old 07-22-2013, 03:12 PM
Default Noise levels
I really have not addressed that issue yet, I might try a longer muffler body with
larger diameter built by the guys in LA that build mufflers for rotorary's. They are a little on the pricy side but seem to know a lot about sound control.
The American Autox Series has been pretty good about letting me run it although it is loud and Button Willow does not have sound limits that I am aware of. I really need to get out in the garage and finish preping the car for the new engine but it is so damn hot I can't work more than an hour or two in the morning. I have to put on the race suspension, a new oil cooler and replace all the lines that have nasty bits and pieces in them. I have my new wheels but they have to be torqued , siliconed and have tires mounted too.
The car has to be corner weighted and aligned along with everything else. I wish this were early spring, but that is the way it goes.
Old 08-03-2013, 12:38 PM
Cobra Make, Engine: not yet, gathering parts for ffr
Default ac for the shop ?
I thought by now you would have an A/C for the shop. When my wife built her 4 car garage her brother in law had an insulation company . She was up in the attic running the blow in hose and her kids were supposed to be listening and relaying information. to the guy running the insulation truck. She said the insulation just kept getting deeper and deeper, , at about 4 ft it finally stopped. the truck was empty. The concrete block walls are also insulated and when the temp runs from 60 at night to 90 day temp the garage doesn't get over 70.
Old 08-03-2013, 01:57 PM
Default Garage
I would really like that, I am working out of a slightly over sized 3 car garage with bare walls and open ceiling, with two fans it still gets over 100 in there all the time. My engine shipped Friday from Detroit so I have to get off my rear and get the frame cleaned up and ready along with swapping the suspension.
My goal is to be running before the end of August. The subdivision I am in will not allow me to add on to the garage so I am stuck with what I have.
How is health Tim everything ok now?
