Old 07-24-2013, 05:49 PM
Cobra Make, Engine: SPF #373,Shelby FE Alum Block #077, 488 stroker, Tunnel Port, Dual-TMP DP Holleys
Default composite or polymer gear for FE?
I'm running a Comp cams solid roller. I was looking into buying a composite dizzy gear. They seem to be unavailable in .500 for aftermarket dizzy and also unavailable in .467 for FE though they are available for SBF in .467. I guess the difference, even though they share the same shaft diameter, is either the pin location or gear pitch??
Anyone know of a vendor that sells composite gear for FE? I mean, the composite or polymer gears as they are sometimes called, have been around for a few years now. You would think that these gears would now be available for FE.
Ray
Old 07-24-2013, 10:12 PM
It doesn't matter what kind of engine you have (FE), it's cam material and distributer shaft size, brand.You need to call Comp cams and they'll tell you what you need.
" It ain't no big deal"
Old 07-24-2013, 11:00 PM
Jac Mac's Avatar
I THINK the gear pitch & tooth count is the same on the FE & Cleveland, but shaft sizes & oil pump hex remain different ( please verify this before spending your $$ ). SBF Fords 302 & 351 Windsor have identical tooth count, but different shaft & hex sizes. Check with some of the FE builders like KC, B2 etc to see where they are sourcing this stuff. I have assumed your running std pump & wet sump, If your using a dry sump then a good bronze gear will suffice as there is no pump load then.
I have always meant to look into swapping the oil pump gears for those from a 351 with 5/16" hex, enlarge the pump shaft spigot in the block & fit the 351 shaft into the FE dizzy to over come some of the issues, but the need has not arisen yet, but getting closer!!
Jac Mac
Old 07-25-2013, 04:06 AM
Neither...
Run a steel gear from Crane or Mallory. If you tell me which distributor you have, I can give you a part number. I have the Crane gears in stock for an MSD...if you need one, let me know.
Old 07-25-2013, 06:06 PM
We use the Crane gears as well
Readily available in .467, .500 and .531 shaft dia
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 07-25-2013, 06:50 PM
Eljaro's Avatar
Use the steel gear. Install and forget.
Any bronze or composite will wear fast if you use a HV oil pump.
Or do you want to change the gear regularly?
