Like Tree1Likes
Old 08-27-2013, 03:15 AM
Originally Posted by Tom Wells View Post
Hate to say this but it needs saying: solid roller lifters do not last 10K miles....
I would have good faith in a set of Isky Red Zone bushed lifters for that kind of longevity and more....and personally know of a couple guys who have over 10k miles on some pressure fed Comp lifters.
Old 08-28-2013, 03:00 AM
I've personally gone that far (10,000) and more with plain vanilla Comp lifters - but the next guy you see in the parking lot seems to have trouble getting half that. Never have "figured it out" but it does happen. FWIW - I am a fan of tight lash, really good quality springs that are firm enough, and high idle speeds (1000-1200 min).
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 08-28-2013, 03:03 AM
Agreed. Those last 3 points that you mentioned are pretty paramount in my mind.
Old 08-28-2013, 03:28 AM
Gaz64's Avatar
Agreed.
If I ever went to roller (currently flat tappet) I would have a rev kit to keep the roller in constant contact. Valve lash setting is then slightly less critical.
Old 08-29-2013, 03:13 AM
Default you have a P-M
Guy you have a P-M Rick
Old 08-29-2013, 11:03 PM
I think I sent you a reply.
Guy
Old 08-29-2013, 11:34 PM
Jac Mac's Avatar
Same here, but also add that I cut the groove in the lifter bore to get oil on the lobe & roller, had one car that was getting up to its 6th season with no problems, but 'they' got a bit lazy on the lash checks, put a couple of rockers on with the center pivot upside down & that was it!
I have to wonder when I read threads of this nature what the drivers action was when the noise started, was the get it home factor in play?
Jac Mac
Old 08-29-2013, 11:44 PM
My sound happened in the garage so lucky me. When It happened to my Dad, he was on the freeway in the fast lane and could not get over.
