Like Tree3Likes
Old 06-27-2014, 06:56 AM
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Default which intake manifold gasket for 427 SO?
Gotta leak from the intake manifold on my 427 SO. Is there an intake gasket that's best here? Any "pearls of wisdom" for the install? thanx steve
steve meltzer
"I may be wrong, but I'm never in doubt"
Old 06-27-2014, 07:26 AM
NewYorkGuy's Avatar
Cobra Make, Engine: Nissan
"pearls of wisdom" advice- take your car to Kirkham for a complete maintenance service.
The wise man’s life is based around, Fudge You.
Old 06-27-2014, 09:28 AM
FelPro 1247S-3. You can get them from Barry.
Thin film of Motorcraft gray between head and gasket and around water ports on both sides. Center the distributor carefully. Torque bolts from centers out-don't kill them. Piece of cake.
Don't take 'pearls of wisdom' from a guy that drives a Nissan Leaf.
Chas.
Old 06-27-2014, 09:34 AM
NY guy... here's a "pearl" for you: if you have no real constructive advice, which apparently you don't, save the band with. Most of us don't have an the extra $10-15K (with shipping) to do a job that involves a $10 gasket and a few hours of the labor love. Do they change your oil, too?
Chas...thanx for the advice I wanted.
steve
steve meltzer
Old 06-27-2014, 10:20 AM
I did mine a few weeks ago, followed Chas advice, worked like a charm.
I let mine sit overnight for at least 12 hours for curing purpose before adding water and lighting her up.
Old 06-27-2014, 10:23 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
100% agree with Chas - that is exactly what I did (after having leaks with two other alternatives) and it worked perfectly - no leaks. As an added bonus, the grey Motorcraft sealer actually matches the color of the aluminum intake manifold pretty well.
Old 06-27-2014, 11:06 AM
Thanx again guys. Is the Motorcraft gray the same as the Permatex Ultra Gray? thanx agin. s
steve meltzer
Old 06-27-2014, 11:21 AM
DanEC's Avatar
Wouldn't that be like a 2000 mile round trip just to change an intake manifold gasket.
Old 06-27-2014, 11:47 AM
No Steve it's not. It's better for our application than the Perm.
Another tip for the ultra anal like me; I made a simple 'clamp' out of right angle stock from garage door track hangers. After adhering the gasket to the head using a couple of bolts to center them in place, clamp them with short bolts a few hours or overnight, as Tedster did. No gaskets squishing out of place when the intake comes down and full contact with the RTV.
http://
Chas.
Old 06-27-2014, 02:17 PM
Actually it's Motorcraft TA-31 , you can get it at any Ford dealership over the parts counter. Just make sure to check for the expiry date on the tube, most of those parts counter guys are unaware of the shelf life.
Here's another gasket option. I've used them for several years. When I've removed the intake there has been no evidence of leaking or gasket "walking".
Keith Craft uses and sells a COMETIC gasket that Keith must have spec'd to some degree. I'm holding an unused set of these gaskets as I type this. It is sealed in COMETIC packaging and shows this part # info.
FORD KC FE2 KEITH CRAFT
.060" KF INTAKE GASKET
IR797060KF
Old 06-27-2014, 02:39 PM
Also a good piece David. Barry also spec'd the 1247S-3 with FelPro-he used to work there.
I see the KC part is .060 when I think the Fel is .047...
Chas.
Old 06-27-2014, 03:51 PM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
i had problems with the Cometic from KC. Wrinkled up and exposed ports. Lucky oil and water didn't mix! I used a NAPA gasket set that is metal re-inforced. Sorry I don't have the number.
The right angle metal idea above is a good one. I let my gaskets cure overnight before torquing down, too.
Hal
Old 06-27-2014, 08:00 PM
mickmate's Avatar
I believe any steel core one is the way to go. The FelPro these guys recommend is the way to go. The sealant is for Ford diesel engines and works really well. The end gaskets I have done with either a good bead of the Motorcraft or a smear of it on the cork gaskets. Check how big the end gaps are before you decide which way to go. I let them and the intakes set up good in position before dropping the manifold on.
mickmate
http://www.actoncustom.com/
Old 06-28-2014, 05:49 AM
Gotta figure out which heads you have first before you can start picking gaskets out.
Low riser? Medium riser? High riser? Tunnel port?
Old 06-29-2014, 02:54 PM
WOW! thanx for all of the info. I ordered the Fel Pro, but I can return it to Summit. The heads are Edelbrock medium rise and the intake is the dual plane Aluminum Edelbrock RPM, 7015.
Edelbrock recommends their intake gasket, also .060, #7224. I thought that they always recommended their own stuff, but for the single plane intake, they recommended the FelPro we've been discussing. Not sure which to use now. thanx. steve
steve meltzer
Old 06-29-2014, 05:35 PM
Steve-use the 1247S-3 or you'll have leaks eventually.
You wanna do this every year?
Chas.
Old 06-29-2014, 08:01 PM
Thank you so much! should be here Tues. Nice 4h of July project. s
steve meltzer
Old 06-29-2014, 09:19 PM
Roush #1's Avatar
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
I guess I missed something. How did all the recommendations take place when the head and intake type were never mentioned until after the recommendations were made ? I'm with you Brent ??????
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
Old 06-30-2014, 08:23 AM
With the total info available, any change in recs? thanx steve
steve meltzer
