09-08-2014, 09:50 AM
Cobra Make, Engine: TBD
Are you planning to run it in the car or on an engine stand?
Have a little gas to supplement the first few strokes to dribble into the carb. with the butterfly held open.
Either way make sure you see oil pressure from the Distributor drive, the timing should be set in the middle (with the twist of the distributor, enough air flow into the radiator (fans), turn the engine over a few times with out the ignition reconnect the ignition ( Center wire to the distributor for the coil)....kick the tires and light the fires.
If you have a laser temperature gun , measure the temp of each of the exhaust header outputs to make sure all eight are firing.
Tony R.
