Old 10-19-2014, 07:59 AM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
Default Side gapping spark plugs
I understand the thinking behind this, but how many owners actually take the time to alter their plugs. Any care to share any experiences, pluses or issues for what is primarily a street driven car? Curious minds want to know.
The older I get, the faster I was.
Old 10-19-2014, 09:38 AM
bobcowan's Avatar
Not sure what you mean by "side tapping". But I use a standard Autolite copper core plug, gapped to .040".
I have used a Autolite racing plug, which has a cut back ground strap. I don't think it made any difference, though.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 10-19-2014, 10:11 AM
Xack's Avatar
Cobra Make, Engine: West Coast Dreams
Yes, Who is this "Side Tapping" you speak of?
Old 10-19-2014, 10:19 AM
bingo2's Avatar
Cobra Make, Engine: RUCC, SB 331 Stroker
I think he may mean "Side Gapping"; this along with indexing may provide a small increase in horsepower and torque and will most likely go unnoticed by the butt dyno.
Old 10-19-2014, 12:48 PM
Tim7139's Avatar
My apologies, I thought my edit for "gapping" took, but I ran out and it bounced.
Of course I meant side gapping.
Old 10-19-2014, 02:36 PM
Jeff Frigo's Avatar
Do you mean indexing?
Jeff
Mark Donahue
Old 10-19-2014, 04:03 PM
Default Index and trimming ground bridge
tim7139 I have done both. I think it helps with power and also keeps the spark plug cleaner. I run 1 range colder that what spec is. I also run an "E" coil that puts out 70k volts. The coil also has an effect on the spark plugs. I like the copper contacts in the distributor. The jury is still out on using livewires. these have a capacitor in the end of each plug wire and help make silly spark. There was a test done that showed a 3-5 hp gain. Rick L.
Old 10-19-2014, 06:21 PM
Tim7139's Avatar
Thanks. Not really looking at the power angle primarily just a good clean burn, got the hot coil but, hey, every little bit helps.
