Like Tree8Likes
Old 11-10-2014, 10:57 AM
Default Keith Craft 482 8 Stack EFI Engine Build
This is a really nice Engine build we just finished. This engine was based on a Pond Aluminum Block, 4340 Steel Crankshaft, H-Beam Rods and Diamond Pistons to start the short block. We topped it off With a set of are Famous CNC Ported Stage II heads, Matching Hydraulic Roller Camshaft and T&D rockers. The Intake we used is the New Borla 8 Stack EFI intake that we port matched to the heads. And a Fast Computer System. This engine made 612hp and 576 on torque. This should be a hand full in a 2000lbs Cobra. If you have any questions
henrik and rlt3214@aol.com like this.
Keith C
Old 11-10-2014, 11:43 AM
http://i454.photobucket.com/albums/q...psb83a2718.jpg
Keith C
Old 11-10-2014, 11:49 AM
Default FE picture
Keith C
Old 11-10-2014, 12:10 PM
Default Beauty
Beauty.
Dwight, LoBelly, joyridin' and 1 others like this.
Keith C
Old 11-10-2014, 03:24 PM
Bill D's Avatar
Sweet!
Old 07-24-2015, 08:20 PM
fordracing65's Avatar
How much does this efi system cost, how does it compare to the Inglese
PRIDEnJOY
Old 07-25-2015, 09:14 AM
All my life I wondered why did the FE design have part of the head attached to the intake manifold, by all (most) other engine standards. This intake explains it all too me. That engine looks perfect!
Old 07-25-2015, 11:21 AM
cycleguy55's Avatar
Ford probably wanted to balance out the weight between the cylinder heads and the intake. Either that, or they were conspiring to make back surgeons rich off all those foolhardy enough to lean over a fender and attempt lifting a cast iron FE intake by without a hoist.
MOTORHEAD likes this.
Brian
Old 07-27-2015, 11:12 AM
Default 482
Sounds nice kieth whats the compression and cam specs
Old 07-27-2015, 11:17 AM
There seems to be a problem with the KC website?
Old 07-27-2015, 03:48 PM
sometimes through this site there is, but if you go google it or go directly to it, their is no problem loading...
PRIDEnJOY
Old 07-21-2016, 07:26 PM
FUNFER2's Avatar
I realize this is a older thread, but is there a dyno sheet on this exact engine ?
Kevin
Old 07-22-2016, 03:30 AM
DanEC's Avatar
Since Keith has backed out of the business it's run by Lance and Tony now from what I understand. Not sure that he drops in on this forum anymore. You may have to call up Craft Performance Engines and ask them, but I'm sure they have a dyno report on it since Keith reported HP & T on it and they have an in-house dyno facility.
ERA 782 Running
Old 07-22-2016, 06:01 AM
FUNFER2's Avatar
Great. Thanks for the reply.
Kevin
Old 07-22-2016, 06:16 AM
Cobra Make, Engine: ERA#134 427 Ctr oiler 2x4's
Default Dyno Sheets
If you go back to the top of this thread, there is a photobucket link that shows the dyno sheets.
Old 07-22-2016, 06:20 AM
FUNFER2's Avatar
Thanks. I was on my tablet last night and I could not zoom in,... to see the sheet, now that I'm on my desk top, I can.
That motor with the injection is what I'm shooting for, if I can afford it anyway. Need to sell some toys and car parts to build another engine.
Again, thanks !
Kevin
Old 07-22-2016, 06:23 AM
FUNFER2's Avatar
Well WTF, I looked at it but now when clicking on the link, it only shows one pic of the engine ? Try it and see.
Kevin
Old 07-22-2016, 07:23 AM
Works for me.
Old 07-22-2016, 09:47 AM
DanEC's Avatar
I missed that.
ERA 782 Running
Old 07-22-2016, 09:52 AM
FUNFER2's Avatar
I don't know what happened last night, but it works for me now too.
Wish it showed the rpm's lower than 4,500.
Kevin
