Like Tree5Likes
  #41 (permalink)
Old 01-01-2015, 06:46 PM
Cobra Make, Engine: Just dreaming at this point
Is that a vacuum pump and if so, why?
  #42 (permalink)
Old 01-01-2015, 06:48 PM
Yes it is. Pulling vacuum on the crankcase, especially with the appropriate ring pack can add some decent ponies....
  #43 (permalink)
Old 01-01-2015, 07:21 PM
DanEC's Avatar
That's very nice. Thanks for posting the details.
ERA 782 Running
  #44 (permalink)
Old 01-02-2015, 02:06 AM
Do heads always need to be retorqued or does it depend on wether headbolts or studs are being used to secure them?
  #45 (permalink)
Old 01-02-2015, 04:23 AM
IMO, yes they always need to be retorqued, both studs and bolts.
If you torque them and mark them, then go back the next day and retorque, you will find that the gaskets have compressed and the fasteners have stretched and they will torque past your mark when you redo them.
Also, this has been the only way I've found MAJOR problems in the past. I had a couple sets of aluminum heads that were not heat treated correctly and were soft. If I had not gone back to retorque, I would have never noticed it.
  #46 (permalink)
Old 01-16-2015, 05:33 PM
Ok, intake was milled, pushrods came in, and the engine is together.
  #47 (permalink)
Old 01-16-2015, 05:40 PM
What manifold is that?
Bill
  #48 (permalink)
Old 01-16-2015, 05:42 PM
Performer RPM.
  #49 (permalink)
Old 03-13-2015, 06:19 PM
FINALLY!!!!!
Got this one dyno'd and delivered today. The weather has been absolutely horrible around here and last week we got dumped with 12" of snow and a little bit of ice. I've been trying to get this one to the dyno for the past 3-4 weeks...
It was a good day. Got the cam broken in, inner valve springs replaced and got some good pulls in.
Final hp was 529 hp @ 5800 and 552 lb-ft @ 4250. Real sweet little engine. Had a nice authoritative idle, accelerated good, made good horsepower...
  #50 (permalink)
Old 03-13-2015, 08:50 PM
Cobra Make, Engine: Scratch Built with 482 FE
Brent,
Nice work! You should move out to California, its 70s here:-) So now for dumb question, who makes the alternator pulley? The ones Ive found and have are stamped.
SB
  #51 (permalink)
Old 03-14-2015, 04:04 AM
Came with the alternator....
  #52 (permalink)
Old 03-14-2015, 05:02 AM
DanEC's Avatar
Wow - that seems like a very health torque figure for a stock cranksaft 427. Should be a nice street performer.
ERA 782 Running
  #53 (permalink)
Old 03-14-2015, 05:31 AM
Generally, a tighter LSA helps make good torque numbers...
