Old 01-31-2015, 01:09 PM
DanEC's Avatar
Default FE light tap & rattling noise
I have a couple video files of engine noise but unfortunately they may not be clean enough to tell much. This is probably the most useful one.
[ame]https://www.youtube.com/watch?v=80q_sC9j8qM[/ame]
The car has under 300 miles on it and it has had a light tapping most of the time. I don't remember it when I first fired up the motor in the car but the header ceramic coating failed immediately and had to be re-done and I changed the break in oil out before starting it again. That is when I first remember hearing some light tapping noise. The car currently has 10W-30 oil in it and runs about 20 to 25 psi at hot idle.
The motor has a flat tappet hyraulic cam with adjustable rockers. Today I very carefully ran the preload settings "again" using the ICE/EOI process for each cylinder, using movement of the rocker and up/down on the pushrod to verify 0-lash, and then lashed them 3/4 more turn. All the lifters were still pumped up when I started the adjustments so I don't think it's a lifter that is stuck or not pumping up. When finished the noise may be a little slighter but it's still there.
I've been all over the motor with a stethescope, a long screw driver and a length of rubber hose and I can't isolate the noise anywhere. i've tried all along the valve covers, exhaust ports, intake, the fuel pump, etc. The noise does seem to be a little more to the passenger side of the engine.
When adjusting the lifters I did notice that the tin drain pieces on the driver side looked to be right against a couple of the springs so I bent them slightly away but that didn't appear to be the issue. Couldn't see anything else on the valve train that seemed out of place.
It actually seems a bit louder underneath or through the side vents as I tried to indicate in the one video where I stuck the camera down by the rocker. All that makes me wonder about an exhaust leak except for 2 things. One, I'm running SCE copper gaskets and two, when driving along with light engine load it will go through cycles of whirrling, rattling, racket - with the top on right now I really hear it. Step on the gas and it quiets down. I have undercar exhaust - I probably would have a harder time hearing it over side exhaust.
Motor runs good without issues. Plugs a bit sooty but dry. No issues otherwise. It's been nearly 35 years since the last motor I had with headers. Header always make some noise but I don't remember them sounding as thrashy as this. I've also had the headers loose and tightened back 2 or 3 times and wonder if the SCE gaskets just aren't sealing anymore. All my header slip joints were sealed with Walkers exhaust joint sealer. I figured the SCE gaskets would be good for several cycles of removal/replacement but maybe not??? Anybody had an issue with copper gaskets not re-sealing in reuse? Sound like an exhaust leak? Worth getting another set of those pricey gaskets?
Trying to eliminate all obvious ideas before turning to the builder.
ERA 782 Running
Rate This Thread:
