Old 02-28-2015, 12:39 PM
brettco's Avatar
Cobra Make, Engine: Hi tech 427 SC
Default valve train noise
I bought a pond aluminum 482 with hydraulic roller 248/252 635 lift and had enough valve train noise to double check the camcard for hydraulic on it. My other engine is flat tappit hydraulic at 610 lift and seemed much quieter? Qlso is a ultra hp 750 big enough? My 470 came with a BG modified 950cfm holley. Thanks
Old 02-28-2015, 02:00 PM
Depends on the lobes that were used. If you use some aggressive lobes, they will sound like a sewing machine.
That's all said with the thinking that your valves are adjusted correctly and there are no other engine issues.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 02-28-2015, 02:52 PM
cycleguy55's Avatar
My engine is a 385 (460 CI), not an FE, but it had a noisy valve train when I took delivery in July. It didn't take me too long to discover it was set up like a mechanical cam with valve lash. It's much quieter and runs much better now that the valves have been properly adjusted to pre-load the hydraulic lifters.
Brian
Old 02-28-2015, 04:18 PM
DanEC's Avatar
My flat tappet hydraulic cam in my 459 seems to have a lot of valve train noise too. The pre-load has been very carefully adjusted so I'm beginning to assume it may be the cam ramps or the Ford rockers/shaft are generating a little noise. Pretty sure it wouldn't have been an acceptable level of noise in a LTD or Thunderbird originally.
ERA 782 Running
Old 02-28-2015, 05:40 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Just pull the valve covers and reset all the valves, hydraulic valves are easy.
" It ain't no big deal"
Old 02-28-2015, 06:03 PM
brettco's Avatar
Old holley 950 or newer 750 ultra hp for a 482?
Old 03-01-2015, 04:11 AM
QuickFuel q-850...
Old 03-01-2015, 10:08 AM
brettco's Avatar
Story of my life. I own a 750 and a 950 qnd can't spend $799 on a 850 but i think i get to keep my ship when she moves out. I guess ill try them both.
