Old 07-10-2015, 07:20 AM
kep's Avatar
kep kep is offline
Registered User
Cobra Make, Engine: BDR 427cu. in.
Default puke tank level?
Hey guys,
Im new here and not sure if I am in the right place.
I have a BDR with a 427. Its been running on the hot side compared to last year. Last year it was around 80 c. Now its between 90 - 100 c. how full do I need the puke tank to be , and what mix do I use?
Thanks lots, Kep
Old 07-10-2015, 07:56 AM
Originally Posted by kep View Post
Hey guys,
Thanks lots, Kep
1) The expansion tank is "self regulating," in that it will spit out the coolant until it finds its correct level -- you can't really overfill it (you'll just end up cleaning it up off the garage floor). FWIW, my level is about a half inch above the bottom of the tank.
2) 80 degrees is a little cool, 90 to 100 is not unusual in the least. Chances are, there is absolutely nothing wrong with your engine.
Old 07-10-2015, 03:18 PM
DanEC's Avatar
Mine runs about 1/2 full and I'm not loosing any water - but my car runs around 80 - 85 also. I only have a 160 F thermostat in it so that could be a bit of it - but once it opens - its open.
ERA 782 Running
Old 07-10-2015, 03:30 PM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Mine self-regulates at half full.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
Old 07-10-2015, 04:50 PM
... and the higher the water to coolant ratio, the better it dissipates heat. But, the freeze point is higher, so be careful if you're in a state that sees a real winter. If you go with straight distilled water, then make sure you add a supplement, such as Water Wetter, to help lubricate & protect the water pump and what not. In fact, I use Water Wetter along with my 50/50 mix of plain old green coolant. And I flush it all out every three years.
Old 07-17-2015, 06:59 AM
Cobra Make, Engine: ERA with a 428 FE that runs on pump gas, but has plenty of power.
I am not suggesting that you have an issue at all, but; on my 428 FE the engine ran up to 195 to 205 degrees F in the summer months, and would almost over-heat at traffic lights on a hot day.
The timing was too far advanced.
I adjusted it with the timing light at 30 degrees and ran the engine up until I achieved full advance, then adjusted to zero on the timing mark on the balancer.
On a hot day now; the temp is 170 F to 180 F.
The car has a 180 degree thermostat.
I had already installed an advance kit for my MSD distributor and 6A ignition box.
Don
Rate This Thread:
