| 29 |
07-12-2015, 11:07 AM
Registered User
428 cobra jet engine block value
I've got a stripped engine block that is either a 427 or 428 cobra jet (it was confirmed by the engine guy from cobra automotive) it has verticals ribbing along the outside of the block which I'm told means that it was a replacement block rather than one installed in a cobra from the factory, I haven't been able to find any stripped blocks for sale to get an idea of what it's worth, I know regular stripped 428 blocks aren't really worth anything, but was told that the cobra jet blocks are different, any ideas on what it's worth?
07-12-2015, 11:27 AM
Senior CC Premier Member
Well first we know it's not a sideoiler. Yes, the ribs would indicate a "service block".
Some numbers around the oil filer area will help nail down what it is. Look for something like C_AE _.
A few pics of the underside of the block might help as well.
Also, since it is stripped, take a flashlight and look into the freeze plug holes for a possible casting that says "428" on the outside of the cylinder casting.
07-12-2015, 11:39 AM
KY
Post all the numbers that you can....casting numbers, bore size, etc.
A regular 428 block is worth a good bit of money. However, most service blocks (the ones with ribs) are of the 390 flavor....and if you have one that's been bored out to a 428 bore, it's most likely junk now.
07-12-2015, 02:31 PM
Well, CentralCTguy....a few things.
As you only made your first post here, you might want to engage and respond.
Plenty of folks here ready to help you out including me, but this can be a rough crowd if you are not showing true interest in people's input.
Just sayin'....
07-12-2015, 03:09 PM
SA
Just sayin'....
....it's only three and a half hours since he posted.
Just saying'....
07-12-2015, 03:33 PM
Got me there.
See where it goes....
07-13-2015, 05:24 AM
AL
let's keep this near the top
bump
Dwight
08-26-2015, 09:40 PM
Registered User
Co
Cobra Make, Engine: 428 super cobra jet
428 value
I just bought a 428 cobra jet motor. It has a C hand welded on the back of the engine and has the correct bore. It also has the ribs down the side of the motor. It came with the Pistons that were marked with a 428 and the word super. From the research I have done, I believe this means that it is a 428 cobra jet service block. I paid $1,000 for it
