Like Tree2Likes
Old 10-12-2015, 03:37 PM
A98Coupe's Avatar
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
Default Shelby Block Rear Main Seal Leak
I have a new Shelby 468 and after only 18 miles running, it is leaking a fair amount of oil at the rear main cap.
The oil appears to be leaking at the oil pan gasket exactly where the gasket passes over the main cap / block joint on both sides. I'm using an Aviad oil pan + windage tray.
I've found some threads on CC and also FE forum explaining problems with early Shelby blocks leaking due to insufficient drain hole size in the rear main cap and explanation how to modify the main cap & oil pan to solve the problem. However, the photos seem to have been removed from the threads so I can't see the before & after countermeasures.
Can anyone help with the following:
1) Pictures of how the Shelby rear main bearing cap oil leak it countermeasured
2) Has anyone tried to remove an Aviad oil pan from an FE mounted in a Kirkham? Can it be done?
Oh, before anyone chimes in with the leak is probably coming from somewhere else an find it's way to the rear.......It isn't. I've checked ALL the usual FE leak spots and then some. The motor is dry except for the rear main seal area.
Many thanks
Stuart
Old 10-12-2015, 05:26 PM
Try here
FE Technical Forum
Old 10-13-2015, 05:39 AM
A98Coupe's Avatar
Brooklyn-427,
Thanks for the link, I'll try seaching through that later tonight.
Anyone else got some more direct info. / experience with Shelby FE blocks?
Old 10-13-2015, 11:52 AM
Cobra Make, Engine: ERA 714
I have Block 597 and have a similar leak. I have managed to slow it considerably by taking some RTV to the rear of the pan where it mounts up to the block. I am not sure that the repair is worth going after trying to fix it unless you can be 100% sure it will be fixed. I also run the Aviad oil pan. I think the rear of the intake seal also leaks and drains down the blockplate and drips. It may be worth using the dyes to verify that it is alll coming from that location.
Phil
Old 10-13-2015, 12:15 PM
A98Coupe's Avatar
Thanks Phil,
My block is CSX472 so earlier than yours and should have the improved drain in the rear main cap. Do you know if your main cap was the improved version from Shelby? I've also thought about applying some RTV between the pan & block plate, but that does feel like a temporary sticking plaster over the root cause. You are right though, I could spend a lot of time & effort removing the engine and trying to re-seal that area only to find it's no better. I have checked everywhere else and I'm pretty sure it's the rear seal. Life's a b*tch sometimes!
Stuart
Old 10-13-2015, 01:04 PM
Bernica's Avatar
Senior CC Premier Member
I have Shelby block #197 and the Aviad pan too.
Thanks to this site, I am a firm believer in the Motorcraft TA-31 RTV sealant (amazing nasty stuff!) and I always keep a pair of Milodon #40450 pan gaskets hanging on the wall just in case. I have yet to have to use them.
As far as removing an Aviad pan in the car, I seem to remember the Kirkham's posting some advice on that subject a long time ago. Might do another search or give them a call.
All that said, I have minimal problems with rear leak. Knocking on wood!
Old 10-13-2015, 01:46 PM
A98Coupe's Avatar
Thanks Bernica,
If I can't find the thread, I might e-mail David to confirm an easy way of removing the oil pan without removing the engine.
Old 10-13-2015, 01:51 PM
just a thought.. i read in another thread about a aviaid oil pan that was fitted using bolts rather than studs, the result was the bolts were a tad too long and had not clamped the pan down onto the gasket enough, thus causing a leak because the bolts were a fraction too long. They swapped out to the correct studs and corrected the problem. Worth looking too see if you have bolts or studs.
Old 10-13-2015, 03:50 PM
A98Coupe's Avatar
Brooklyn-427,
Thanks for the thought, but I have studs & nuts. I also checked tightness because I know the gaskets can relax a little from new. However, all nuts seemed snug. I guess I've been unlucky with this engine. Don't whether to try and bodge it with RTV as Large Arbor suggests and then live with it until I need to pull the engine again, or bite the bullet now after only 18 miles of running and pull the engine and try an re-seal the rear main cap seals.........sooooooo frustrating! I finally got to experience 600hp in a lightweight Kirkham and was blown away by the acceleration. All I want to do is drive the thing and enjoy it.........not blow oil out of the back of the engine!
Old 10-13-2015, 04:36 PM
Bernica's Avatar
Do you also have a windage tray installed?
Old 10-13-2015, 05:01 PM
Hey since talk is cheap, my oil problems were related to an engine builder improperly calibrating the oil dip stick...The full line was about 50% beyond the capacity of the pan manufacturer's figure. When i filled mine to the oil pan mfg's figure my dipstick didn't register anything.
Could it be that you simply have too much oil in the engine? Filling it clear up to the seal?
Just a thought.
Superformance 1764
Built 427W
Aiken SC USA
Old 10-13-2015, 05:48 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Not likely, tortuga. FE's leak before they're assembled
I don't mind the leak in itself, it's the mess it makes on the chassis.
That's why I'm in the process of experimenting with diapers (New Pig strips with Gorilla tape at the bottom of the bellhousing and between the block and blockplate). Normally I wouldn't think of such a cockamamie scheme but I have so much access now that I have a Kwik Lift...
...I can see every pinhead sized drop, with my own pinhead eyes
rodneym
Old 10-13-2015, 06:55 PM
Bernica's Avatar
Like my old Jags...
If I don't see oil on the floor, then something is wrong!
Old 10-14-2015, 05:47 AM
A98Coupe's Avatar
Bernica,
Yes I have a windage tray installed, it cam with the Avaid oil pan.
Tortuga,
I have calibrated the dipstick according to Avaid's procedure - put 9 qrts in from empty - mark dipstick 'Full' - start engine and run until primed, then stop & allow oil in pan to settle - Mark dipstick 'Low' - top up with oil to the full mark. It might be worth reducing oil volume to 8 qrts and see if the leak diminishes?
General question for everyone: Do you run 8 or 9 qrts with an FE Avaid pan?
Old 10-14-2015, 08:36 AM
Stuart
How do you find the CR toploader with the 3.07?
Old 10-14-2015, 10:53 AM
I run 9 quarts when I run which for past month has not been any due to starter alignment issues. Going after that issue this weekend.
Phil
Old 10-14-2015, 11:05 AM
Bernica's Avatar
I am at 11 quarts with the Aviad and an oil cooler. I always buys a case and have one left.
Old 10-14-2015, 03:57 PM
A98Coupe's Avatar
Originally Posted by Brooklyn-427 View Post
Stuart
CR Toploader is fine with a 3.07 rear end. 1st gear is fairly tall but manageable in traffic, motorway cruise at 80mph around 3,000rpm. Acceleration between gears is pretty rapid. I don't like 5 speed gearboxes in a Cobra.
Dominik likes this.
Old 10-14-2015, 04:01 PM
A98Coupe's Avatar
Phil
Thanks Phil,
Looks like I'm not overfilling anyway.
Old 10-14-2015, 05:13 PM
Bernica's Avatar
I run 3:31 with a WR and like the setup. Yes, I'm not a fan of 5 or 6 speeds either!
Dominik likes this.
