Old 06-15-2017, 07:34 AM
Registered User
Cobra Make, Engine: Superformance 427 Shelby aluminum block stroked to 484
Default Brake Pads
Does anybody know what Brake pads were put on the early model Superformance Cobras it has a spring clip on the outside pad and a bracket that goes into brake calper I need part number. My car 1363
Old 06-15-2017, 08:29 AM
Senile Club Cobra Member
Do you have Wilwood calipers? By you car number I would expect Wilwoods. The pads you are describing are the early pads used with the sliding caliper Ford Granada (1975-1979) brakes. These are DM152 for the backing plate indicator and are available in many pad material types. The Wilwood pads are held in by two pass-through cotter pins.
Contact us if you need help identifying the parts.
rick@autoventureusa.net
Old 06-15-2017, 08:32 AM
Also posting in the "FE" section will reduce the chance of people seeing your question and being able to help. The "all Cobra talk" or better yet, the "Superformance" forum will generate more views and replies.
info@timemachinesauto.com for tech help
